July 14, 2022, 16:47 |
snappyhexmesh not create cellZone; for dynamicMesh
Rep Power: 6 |
Hi guys, would be super apprecitae if someone can give a help here
I tried to create cellzone and facezone with snappyhexmesh in order to run dynamic mesh, like rotatingFanInRoom case did. But it didn't create one and I didn't find the reason Here is how the SHM looks: I created a AMI using searchableBox, and tried to define the cellZone with refinementSurfaces: Code:
geometry { FRCfull.stl { type triSurfaceMesh; name bridge; } busfull.stl { type triSurfaceMesh; name bus; } AMI { type searchableBox; min (39.5 188675 692); max (44.7 188682 747); } }; refinementSurfaces { bridge { // Surface-wise min and max refinement level level (7 7); patchInfo { type wall; } } bus { // Surface-wise min and max refinement level level (7 7); patchInfo { type wall; } } AMI { // Surface-wise min and max refinement level level (7 7); faceType boundary; cellZone motioncell; faceZone motionface; cellZoneInside inside; //insidePoint (41.1 188680 731); } } Code:
Mesh stats points: 85813080 faces: 244567590 internal faces: 236510331 cells: 79390494 faces per cell: 6.0596414 boundary patches: 19 point zones: 0 face zones: 1 cell zones: 1 ..... Checking topology... Boundary definition OK. Cell to face addressing OK. Point usage OK. Upper triangular ordering OK. Face vertices OK. *Number of regions: 2 The mesh has multiple regions which are not connected by any face. <<Writing region information to "0/cellToRegion" <<Writing region 0 with 79273836 cells to cellSet region0 <<Writing region 1 with 116658 cells to cellSet region1 Code:
--> FOAM FATAL ERROR: Unable to find cellZone motioncell. Valid cellZones are:0() anyone could give me any suggestion? thx Last edited by MudaMuda; July 16, 2022 at 04:58. |
cellzones, snappyhexmesh |
[snappyHexMesh] snappyHexMesh does not create any mesh except one for the reference cell | Arman_N | OpenFOAM Meshing & Mesh Conversion | 1 | May 20, 2019 17:16 |
[snappyHexMesh] SHM doesn't create cellZones for one region | Eko | OpenFOAM Meshing & Mesh Conversion | 10 | January 24, 2018 02:03 |
[snappyHexMesh] snappyHexMesh does not create mesh in body volume | Illmatic | OpenFOAM Meshing & Mesh Conversion | 1 | July 11, 2016 21:35 |
[snappyHexMesh] How to create internal boundaries using snappyHexMesh | robyTKD | OpenFOAM Meshing & Mesh Conversion | 2 | October 19, 2014 09:57 |
Where's the singularity/mesh flaw? | audrich | FLUENT | 3 | August 4, 2009 01:07 |
