Time-varying heat transfert coefficient (htc) with externalWallHeatFluxTemperature BC |
July 22, 2021, 02:58 |
Jordan EINRICK
Hello everyone,
I am trying to set up the boundary condition externalWallHeatFluxTemperature in coefficient mode as follows : top { type externalWallHeatFluxTemperature; mode coefficient; Ta constant 300.0; h constant 10.0; kappaMethod fluidThermo; value uniform 400; } It works like this. In my research I managed to set up Ta from a data table (time dependent), but I would like to go further and set up the heat transfer coefficient (bold line in code) as a time dependent variable which will be defined from a data table. After some research[1], I know that Ta is defined as a Function1 type but h is defined as a patchFunction1 type and I don't know how I can set up the value of a patchFunction1 variable from a data table (even if I know it is possible). [1] https://www.openfoam.com/documentati...alarField.html Please, could you help me setting up this condition ? Thank you in advance, Jordan |
August 7, 2022, 07:04 |
Utkan Erdem
Rep Power: 5 |
I am trying to do a similar thing. I want to specify time-varying heat flux condition with externalWallHeatFluxTemperature BC. Did you find a solution to your problem? |
convection heat flux, heat tranfer coefficient, htc, patchfunction1, time-varying |
courant number increases to rather large values | 6863523 | OpenFOAM Running, Solving & CFD | 22 | July 5, 2023 23:48 |
AMI speed performance | danny123 | OpenFOAM | 21 | October 24, 2020 04:13 |
laplacianFoam with source term | Herwig | OpenFOAM Running, Solving & CFD | 17 | November 19, 2019 13:47 |
pimpleDyMFoam computation randomly stops | babapeti | OpenFOAM Running, Solving & CFD | 5 | January 24, 2018 05:28 |
Question about heat transfer coefficient setting for CFX | Anna Tian | CFX | 1 | June 16, 2013 06:28 |
