Re: value of Drag force, lift force, and pressure unexpected
Hello to all
I got some different values of cl and cd snd pressure as well. My case is a 2D airfoil; the flow comes from a downward Y direction to the upward Y. U=10.5 m/s and moving wall boundary condition. this is my pimple simulation file HTML Code:
ExecutionTime = 39151.23 s ClockTime = 40502 s |
The simple answer is your simulation is diverging. If that is not the case then you have used wrong boundary or initial conditions.
How can I know that my initial boundary or boundary condition is wrong? please check my boundary file HTML Code:
6 |
Can you show your model in diagram? I have just noticed that y+ value is very high (assuming you are using a low- Reynolds Turbulence Model).
Which diagram do u want to see? |
The model you are using for simulation.
Can you send me your Email-ID? I will send you the whole file and you can check it. |
1 Attachment(s)
I am not sure what you trying to achieve, your Inlet has normal in x direction but it has velocity value in y direction. Are you trying to rotate airfoil to change angles of attack?
My inlet is IN Y-direction upward and outlet is top od Y-direction and have moving wall left and right as mentioned in blockMesh. I am not trying to change AOA. Thanks |
Are you using dynamic mesh in your simulation?
Have you checked my files? Where am I wrong? |
One thing I noticed is nut value is 0 in initial condition. I would choose it 0.1 times of nu. Since you are not using dynamic Mesh there is no point in using AMI Interpolation. It just add additional computation cost. Last thing I will suggest is reducing max Co in controlDict to 5 from 20.
I have periodic boundary the left and right walls. Do u think I should use MRF Property? I still do not understand why I can not use AMI interpolation? Thanks |
You can use periodic boundary condition for that. AMI and MRF are mainly used when mesh motion is involved.
That is why I used CyclicAMI as a periodic boundary condition. |
I am talking about this https://www.openfoam.com/documentati...ed-cyclic.html
Here you can get more Info https://www.cfd-online.com/Forums/op...cyclicami.html |
After reading this I have not found any wrong with my Boundary conditions. Have you seen anything wrong? |
I don't understand why are using cyclic boundary condition? Your simulation involves measuring Cd and Cl on a airfoil. Anyways you probably need to edit nut initial condition and run the simulation. And also add log file of your simulation if you encounter any error it helps a lot.
