October 6, 2022, 05:42 |
Dynamic Mesh Error
Sanjay R
Rep Power: 3 |
I am trying to simulate an oscillatingrotatingmotion of an airfoil with Spalart-Allmaras and when i command moveMesh or ./Allrun, i get this error.... FOAM FATAL ERROR: fvMeshStitcher for changing mesh not found Valid fvMeshStitchers are : 1(stationary) From function static Foam::autoPtr<Foam::fvMeshStitcher> Foam::fvMeshStitcher::New(Foam::fvMesh&, bool) in file fvMesh/fvMeshStitchers/fvMeshStitcher/fvMeshStitcherNew.C at line 86. Could anyone tell me what would be the reason for this error? |
October 9, 2022, 12:02 |
Prakriteesh Sarma
Rep Power: 9 |
Hi SanWick002
Please check my reply here: fvMeshSticher Maybe you have a similar issue in your case? |
October 10, 2022, 13:34 |
Sanjay R
Rep Power: 3 |
Yeah... This solved my problem...
Thanks for the help fluxCatcher |
Building OpenFOAM1.7.0 from source | ata | OpenFOAM Installation | 46 | March 6, 2022 13:21 |
[swak4Foam] GroovyBC the dynamic cousin of funkySetFields that lives on the suburb of the mesh | gschaider | OpenFOAM Community Contributions | 300 | October 29, 2014 18:00 |
Ansys Fluent 13.0 UDF compilation problem in Window XP (32 bit) | Yogini | Fluent UDF and Scheme Programming | 7 | October 3, 2012 07:24 |
CGNS lib and Fortran compiler | manaliac | Main CFD Forum | 2 | November 29, 2010 06:25 |
How to get the max value of the whole field | waynezw0618 | OpenFOAM Running, Solving & CFD | 4 | June 17, 2008 05:07 |
