Help please, can not fix error
Hello all,
I have a question about one of jet flow simulation in OpenFoam. I try to run the Jet flow work but when I run the code, I get an error. please Can you help me? Thank you so much The error: (I remark the line 56 in the error) --> FOAM FATAL IO ERROR: Essential value for keyword 'field' not set In function entry: scalarTransport In file: /home/mhy/Desktop/OpenFoam/OpenFOAM-Cases-Interfluo-main/Canonical-Flows/jet/case1/system/controlDict at line 56 The function entry should be: scalarTransport(field = <fieldName>) file: /home/mhy/Desktop/OpenFoam/OpenFOAM-Cases-Interfluo-main/Canonical-Flows/jet/case1/system/controlDict/functions/scalarTransport from line 19 to line 27. From function static bool Foam::functionObjectList::readFunctionObject(const Foam::string&, Foam::dictionary&, const Foam::Pair<Foam::string>&, const Foam::word&) in file db/functionObjects/functionObjectList/functionObjectList.C at line 416. FOAM exiting Code:
FoamFile |
The error message informs you there is an issue with scalarTransport function which is included just before line 56: Code:
#includeFunc scalarTransport Code:
The function entry should be: Also, please be careful to give a proper title when you create a new thread. (https://www.cfd-online.com/Forums/op...-get-help.html) Regards, Yann |
