Dimension incompatible
Old   February 23, 2023, 00:39
Default Dimension incompatible
VanLap Nguyen
laptmu is on a distinguished road
Dear Everyone,
I am new in OpenFoam, now I am building a solver (PisoFoam2) based on PisoFoam.
In the momentum equation of PisoFoam is divided by rho. But I would like to build a solver that considers rho in the momentum equation, and it is not compressible.
This is my UEqn code.
fvVectorMatrix UEqn
fvm::ddt(rho, U) + fvm::div(rhoPhi, U)
+ turbulence->divDevRhoReff(U)
fvOptions(rho, U)
UEqn.relax();
fvOptions.constrain(UEqn);
if (piso.momentumPredictor())
solve(UEqn == -fvc::grad(p));
fvOptions.correct(U);
I defined rho and rhoPhi in createFields.H, and in running case I changed the pressure file p to kg/m.s^2.
I compiled successfully but when I run it showed that
--> FOAM FATAL ERROR:
incompatible dimensions for operation
[U[1 -2 -2 0 0 0 0] ] + [U[0 1 -2 0 0 0 0] ]
Please help me to solved this errors.
laptmu is offline   Reply With Quote
Gmsh reports an OpenCascade exception when opening a .geo file algc Main CFD Forum 2 October 24, 2022 06:59
[ANSYS Meshing] Refinement dimension is not working Tasos ANSYS Meshing & Geometry 0 May 13, 2017 10:07
Incompatible dimensions for operation ruben23 OpenFOAM Running, Solving & CFD 2 June 12, 2015 05:14
incompatible dimension for operation means?? Tushar@cfd OpenFOAM 4 June 30, 2011 06:13
incompatible dimension with interFoam aurelia OpenFOAM Running, Solving & CFD 2 February 6, 2006 12:06
