Command 'blockMesh' not found
Hi, I am an absolute starter on Openfoam, and as I was going through OpenFOAM's Wiki learning path video, I was stuck when trying to create a mesh from one of the tutorial cases using the blockMesh command. I have been trying for hours but still could not figure it out what is causing this problem:
Command 'blockMesh' not found, but can be installed with: Can someone help me to solve this problem? Thankfully, Gustavo |
What Video did you watch? Did you source the OpenFOAM Environment?
1 Attachment(s)
https://youtu.be/CeEJS1eT9NE Those are the steps that I took (in the picture). I am sorry, but what exactly it is to source OpenFoam? |
Sorry i cannot help you further, because this is for the WSL. I use native Linux and have no experience with OpenFOAM and the WSL. But Mr Nagy explained how to source OpenFOAM in Chapter 7 of his Video (ca. 10:51 on). So far so good.
