No MRF models present
Dear all,
I'm new on OpenFoam. I'm training with the models in this link: https://github.com/iatnart/ac-room I'm trying to solve the 'buoyantFoam' and I get the message /*---------------------------------------------------------------------------*\ ========= | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox \\ / O peration | Website: https://openfoam.org \\ / A nd | Version: 10 \\/ M anipulation | \*---------------------------------------------------------------------------*/ Build : 10-c4cf895ad8fa Exec : buoyantFoam Date : Jun 23 2023 Time : 15:04:29 Host : "DESKTOP-H5IDDY0" PID : 588 I/O : uncollated Case : /mnt/e/googledrive/05-OpenFOAM/02.Project/01-SGF_LA/00.S6-bouyant nProcs : 1 sigFpe : Enabling floating point exception trapping (FOAM_SIGFPE). fileModificationChecking : Monitoring run-time modified files using timeStampMaster (fileModificationSkew 10) allowSystemOperations : Allowing user-supplied system call operations // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // Create time Create mesh for time = 0 PIMPLE: Convergence criteria found p_rgh: tolerance 0.0001 U: tolerance 0.0001 h: tolerance 0.0001 "(k|epsilon|omega)": tolerance 0.001 PIMPLE: Operating solver in steady-state mode with 1 outer corrector PIMPLE: Operating solver in SIMPLE mode Reading thermophysical properties Selecting thermodynamics package { type heRhoThermo; mixture pureMixture; transport const; thermo hConst; equationOfState perfectGas; specie specie; energy sensibleEnthalpy; } Reading field U Reading/calculating face flux field phi Creating turbulence model Selecting turbulence model type RAS Selecting RAS turbulence model kOmegaSST Selecting patchDistMethod meshWave RAS { model kOmegaSST; turbulence on; printCoeffs on; alphaK1 0.85; alphaK2 1; alphaOmega1 0.5; alphaOmega2 0.856; gamma1 0.555556; gamma2 0.44; beta1 0.075; beta2 0.0828; betaStar 0.09; a1 0.31; b1 1; c1 10; F3 false; } Creating thermophysical transport model Selecting thermophysical transport type RAS Selecting default RAS thermophysical transport model unityLewisEddyDiffusivity Reading g Reading hRef Calculating field g.h Reading pRef Reading field p_rgh Creating field dpdt Creating field kinetic energy K No MRF models present No fvModels present No fvConstraints present I don't know to fix this and why I get the problem. Thank for all, |
No MRF models present It's perfectly fine, unless you were trying to use one of these functionalities. These are optional features, your solver does not need it to run you case. If the solver crashes, it's related to something else. Don't you get an error when it stops? Regards, Yann |
the message above was all content when I tried to on Bash ubuntu on window When I ran on Linux so that's the message: Code:
OK so basically the solver crashes the moment it tries starting time loop.
The classic Foam::error:: printStack happens when some math get wrong (for instance it ends up trying to divide something by 0) and it doesn't clearly tell you what is wrong. (more details here: https://www.cfd-online.com/Forums/op...rintstack.html) We can see this block in your log: Code:
#3 Foam::divide(Foam::Field<double>&, Foam::UList<double> const&, Foam::UList<double> const&) at ??:? After a quick look at your boundary conditions, I see you defined inletOutlet BC for nut on all your inlets and outlet: Code:
boundaryField Your error might be related to the fact you impose nut=0 on your inlets and outlets. Try to replace it by calculated BC and rerun your case. I cannot guarantee this is the cause of your error and I didn't check the rest of your case setup. If it doesn't solve the issue, repeat the process, and compare your case with some tutorials to spot differences and potential errors. Good luck! Yann |
