How can I modify config(controlDict, fvSolution, ... etc) to use AmgXWrapper?
Old   July 25, 2023, 05:56
Question How can I modify config(controlDict, fvSolution, ... etc) to use AmgXWrapper?
STK
Seungtae Kim
STK is on a distinguished road
Hellow foamers,
I'm seeking the way to solve CHT(conjugate heat transfer) with GPU acceleration.
My first attempt is using RapidCFD. But chtMultiRegionFoam(originally commented out) in RapidCFD cannot handle compressible::turbulentTemperatureCoupledBaffleMix ed; boundary condition (which is used in OpenFOAM-2.3.x chtMultiRegionFoam tutorial)
And other thread said cudasolver in foam-extended also suffers lack of coupled temperature BC
Thus I try OpenFOAM-PETSc4FOAM-AmgXWrapper as shown in slide 4 following link: https://wiki.openfoam.com/images/a/a..._Martineau.pdf
I can successfully call petsc thanks to the tutorial in PETSc4FOAM source. But I have absolutely no idea how to call AmgX using AmgXWrapper.
Usage page in AmgXWrapper repository gives several command to call AmgXWrapper in PETSc application(https://github.com/barbagroup/AmgXWr...r/doc/usage.md) but I'm not sure where to put those lines like "AmgXSolver solver;" maybe under the petsc dictionary in fvSolution?
Should I add libs (libamgxwrapper); in controlDict to call it?
Is there any test case such that I can check proper configurations?
STK is offline   Reply With Quote
amgx, amgxwrapper, gpu, openfoamv2306, petsc4foam
Problem modify Newtonian transportModel in OF6 aeroBassti OpenFOAM Programming & Development 1 April 16, 2021 12:01
Effects on fvSolution file on calling mpi run aaron99 OpenFOAM Programming & Development 0 May 27, 2019 07:12
How to lock the fvSolution file ? aaron99 OpenFOAM Programming & Development 5 May 17, 2019 12:44
