slip and wedge boundary conditions in the axisymmetric geometry
Old   August 23, 2023, 12:07
Default slip and wedge boundary conditions in the axisymmetric geometry
Ching Liu
qingqingliu is on a distinguished road
I set up a 2D axisymmetric geometry with 1 degree in OpenFOAM. The front and back patches are usually set "wedge". In my simulation, I set part of the front and back patches to "slip" condition, and the remaining front and back patches are set "wedge". The normal component of the velocity with the slip condition should be zero. However, in the simulation results, the normal component of the velocity is not zero at the patch where "slip" boundary condition is applied. I do not find the reason. Perhaps, there is only one layer of grid cell in the direction of front and back patches, the slip condition does not work as expected? Does anyone know the reason?
qingqingliu is offline   Reply With Quote
axisymmetric geometry, slip, wedge
Initial Boundary Conditions setup for hypersonic flow of a double wedge Tegdlemat OpenFOAM Running, Solving & CFD 2 May 13, 2022 15:17
wedge vs rotational cyclic boundary conditions? wildfire230 OpenFOAM Running, Solving & CFD 4 January 2, 2021 10:29
mesh file for flow over a circular cylinder Ardalan Main CFD Forum 7 December 15, 2020 14:06
Wind Turbine blade in 120° wedge - boundary conditions Fcamp OpenFOAM Running, Solving & CFD 1 December 2, 2019 07:47
Slip on walls (Wall Boundary Conditions) Oleg V. FLUENT 15 November 16, 2014 05:49
