rigidBodyLibrary compatibility with solvers
Hello everyone!
I'm here to ask a general question concerning openFoam. Is the rigidBodyLibrary compatible with the solver overPimpleDyMFoam? I was thinking so but now I'm stuck with my simulation receiving the following error message: Quote:
I am fully available to share whatever relevant dictionaries, if needed. If anyone knows, please help! I'm stuck on a very dead point. Many thanks in advance!! |
The problem seems to be related to the definition of density. You should indicate that you are in an incompressible case by adding Code:
rho rhoInf; |
Thank you for your reply gcampana.
Basing myself on some previous threads, I already tried what you suggest me to do. Unluckily, it doesn't work. By the way, I've slightly changed the approach so it is not an urgent stuff. :) Enrin |
