TGS |
October 11, 2023 05:21 |
Error during the snappyHexMesh
Currently, I am using the OpenFOAM V1912. I have a heat transfer problem related to the conventional fin geometry. I successfully created my blockMesh, and then I successfully ran the surfaceFeatureExtract command too. However, while I am running the snappyHexMesh command, I am getting an error. The error is mentioned at the below. At the moment, I am running the programme using a super computer. However, when I was running snappyHexMeshDict on my local computer for the same case, I didn't get any errors. Only I am getting the error while I am running it in the cluster. Initially, I thought it was because of the large mesh size, but I reduced the mesh size as well. However, I am still getting the same error. The snappyHexMeshDict is also attached herewith. Please help me.
\\ / F ield | OpenFOAM: The Open Source CFD Toolbox
\\ / O peration | Version: v1912
\\ / A nd | Website: www.openfoam.com
\\/ M anipulation |
FoamFile
version 2.0;
format ascii;
class dictionary;
object snappyHexMeshDict;
// Which of the steps to run
castellatedMesh true;
snap true;
addLayers false;
// Geometry. Definition of all surfaces. All surfaces are of class
// searchableSurface.
// Surfaces are used
// - to specify refinement for any mesh cell intersecting it
// - to specify refinement for any mesh cell inside/outside/near
// - to 'snap' the mesh boundary to the surface
geometry
finModified.stl
type triSurfaceMesh;
name finModified;
heatedBoundary.stl
name heatedBoundary;
refinementBox
type searchableBox;
min (-1.0 -0.7 0.0);
max ( 8.0 0.7 2.5);
// refinementBox
// type searchableBox;
// min (-1.0 -0.7 0.0);
// max ( 8.0 0.7 2.5);
// Settings for the castellatedMesh generation.
castellatedMeshControls
// Refinement parameters
// If local number of cells is >= maxLocalCells on any processor
// switches from from refinement followed by balancing
// (current method) to (weighted) balancing before refinement.
maxLocalCells 100000;
// Overall cell limit (approximately). Refinement will stop immediately
// upon reaching this number so a refinement level might not complete.
// Note that this is the number of cells before removing the part which
// is not 'visible' from the keepPoint. The final number of cells might
// actually be a lot less.
maxGlobalCells 2000000;
// The surface refinement loop might spend lots of iterations refining just a
// few cells. This setting will cause refinement to stop if <= minimumRefine
// are selected for refinement. Note: it will at least do one iteration
// (unless the number of cells to refine is 0)
minRefinementCells 10;
// Allow a certain level of imbalance during refining
// (since balancing is quite expensive)
// Expressed as fraction of perfect balance (= overall number of cells /
// nProcs). 0=balance always.
maxLoadUnbalance 0.10;
// Number of buffer layers between different levels.
// 1 means normal 2:1 refinement restriction, larger means slower
// refinement.
nCellsBetweenLevels 3;
// Explicit feature edge refinement
// Specifies a level for any cell intersected by its edges.
// This is a featureEdgeMesh, read from constant/geometry for now.
features
file "finModified.eMesh";
level 6;
file "heatedBoundary.eMesh";
level 6;
// Surface based refinement
// Specifies two levels for every surface. The first is the minimum level,
// every cell intersecting a surface gets refined up to the minimum level.
// The second level is the maximum level. Cells that 'see' multiple
// intersections where the intersections make an
// angle > resolveFeatureAngle get refined up to the maximum level.
refinementSurfaces
finModified
// Surface-wise min and max refinement level
level (1 2);
// Optional specification of patch type (default is wall). No
// constraint types (cyclic, symmetry) etc. are allowed.
heatedBoundary
level (1 2);
// Resolve sharp angles
resolveFeatureAngle 30;
// Region-wise refinement
// Specifies refinement level for cells in relation to a surface. One of
// three modes
// - distance. 'levels' specifies per distance to the surface the
// wanted refinement level. The distances need to be specified in
// descending order.
// - inside. 'levels' is only one entry and only the level is used. All
// cells inside the surface get refined up to the level. The surface
// needs to be closed for this to be possible.
// - outside. Same but cells outside.
refinementRegions
refinementBox
mode inside; // default (min max) refinement for whole surface
levels ((1 2));
// faceZone fin_to_air;
// cellZone fin;
// cellZoneInside inside; // Keep mesh in fin region.
// Mesh selection
// After refinement patches get added for all refinementSurfaces and
// all cells intersecting the surfaces get put into these patches. The
// section reachable from the insidePoint is kept.
// NOTE: This point should never be on a face, always inside a cell, even
// after refinement.
insidePoint (-9.0 -69.2 15);
// Whether any faceZones (as specified in the refinementSurfaces)
// are only on the boundary of corresponding cellZones or also allow
// free-standing zone faces. Not used if there are no faceZones.
allowFreeStandingZoneFaces true;
// Settings for the snapping.
snapControls
//- Number of patch smoothing iterations before finding correspondence
// to surface
nSmoothPatch 3;
//- Relative distance for points to be attracted by surface feature point
// or edge. True distance is this factor times local
// maximum edge length.
tolerance 2.0;
//- Number of mesh displacement relaxation iterations.
nSolveIter 30;
//- Maximum number of snapping relaxation iterations. Should stop
// before upon reaching a correct mesh.
nRelaxIter 5;
// Feature snapping
//- Number of feature edge snapping iterations.
// Leave out altogether to disable.
nFeatureSnapIter 10;
//- Detect (geometric only) features by sampling the surface
// (default=false).
implicitFeatureSnap false;
//- Use castellatedMeshControls::features (default = true)
explicitFeatureSnap true;
//- Detect points on multiple surfaces (only for explicitFeatureSnap)
multiRegionFeatureSnap false;
// Settings for the layer addition.
addLayersControls
// Are the thickness parameters below relative to the undistorted
// size of the refined cell outside layer (true) or absolute sizes (false).
relativeSizes true;
// Per final patch (so not geometry!) the layer information
layers
finModified
nSurfaceLayers 1;
heatedBoundary
nSurfaceLayers 1;
// Expansion factor for layer mesh
expansionRatio 1.0;
// Wanted thickness of final added cell layer. If multiple layers
// is the thickness of the layer furthest away from the wall.
// Relative to undistorted size of cell outside layer.
// See relativeSizes parameter.
finalLayerThickness 0.3;
// Minimum thickness of cell layer. If for any reason layer
// cannot be above minThickness do not add layer.
minThickness 0.1;
// If points get not extruded do nGrow layers of connected faces that are
// also not grown. This helps convergence of the layer addition process
// close to features.
// Note: changed(corrected) w.r.t 17x! (didn't do anything in 17x)
nGrow 0;
// Advanced settings
// When not to extrude surface. 0 is flat surface, 90 is when two faces
// are perpendicular
featureAngle 60;
// At non-patched sides allow mesh to slip if extrusion direction makes
// angle larger than slipFeatureAngle.
slipFeatureAngle 30;
// Maximum number of snapping relaxation iterations. Should stop
nRelaxIter 3;
// Number of smoothing iterations of surface normals
nSmoothSurfaceNormals 1;
// Number of smoothing iterations of interior mesh movement direction
nSmoothNormals 3;
// Smooth layer thickness over surface patches
nSmoothThickness 10;
// Stop layer growth on highly warped cells
maxFaceThicknessRatio 0.5;
// Reduce layer growth where ratio thickness to medial
// distance is large
maxThicknessToMedialRatio 0.3;
// Angle used to pick up medial axis points
// Note: changed(corrected) w.r.t 17x! 90 degrees corresponds to 130 in 17x.
minMedianAxisAngle 90;
// Create buffer region for new layer terminations
nBufferCellsNoExtrude 0;
// Overall max number of layer addition iterations. The mesher will exit
// if it reaches this number of iterations; possibly with an illegal
// mesh.
nLayerIter 20;
// Generic mesh quality settings. At any undoable phase these determine
// where to undo.
meshQualityControls
#include "meshQualityDict"
// Advanced
// Write flags
writeFlags
scalarLevels
layerSets
layerFields // write volScalarField for layer coverage
// Merge tolerance. Is fraction of overall bounding box of initial mesh.
// Note: the write tolerance needs to be higher than this.
mergeTolerance 1e-6;
--> FOAM FATAL ERROR:
no points or no cells in mesh
bad size -2147483647
From function Foam::List<T>::List(int, Foam::zero) [with T = int]
in file /lustre/scafellpike/local/apps/intel/OpenFOAM/OpenFOAM-v1912/src/OpenFOAM/lnInclude/List.C at line 141.
FOAM aborting
#0 Foam::error::printStack(Foam::Ostream&) at ??:?
#1 Foam::error::abort() at ??:?
#2 Foam::meshRefinement::printMeshInfo(bool, Foam::string const&) const at ??:?
#3 Foam::meshRefinement::baffleAndSplitMesh(bool, Foam::snapParameters const&, bool, bool, Foam::Field<double> const&, int, Foam::dictionary const&, Foam::Time&, Foam::List<int> const&, Foam::List<int> const&, Foam::Field<Foam::Vector<double> > const&, Foam::List<Foam::word> const&, Foam::Field<Foam::Vector<double> > const&, Foam::writer<double> const&) at ??:?
#4 Foam::snappyRefineDriver::baffleAndSplitMesh(Foam::refinementParameters const&, Foam::snapParameters const&, bool, Foam::dictionary const&) at ??:?
#5 Foam::snappyRefineDriver::doRefine(Foam::dictionary const&, Foam::refinementParameters const&, Foam::snapParameters const&, bool, Foam::meshRefinement::FaceMergeType, Foam::dictionary const&) at ??:?
#6 ? at ??:?
#7 __libc_start_main in /lib64/libc.so.6
#8 ? at ??:?
Aborted
