DTCHullWave solver
so i work on my final task using an openFoam and im still not familiar about this. So im running my task using DTCHulWave tutorial and end up my tutorial solver can run perfectly. And then i tried to change the geometry(object) to the new one that i designe in the autodesk inventor. And after running this solver i got some error message and its causing my new object didnt recognize by system whe i try to running the solver.
/*---------------------------------------------------------------------------*\ ========= | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox \\ / O peration | Website: https://openfoam.org \\ / A nd | Version: 10 \\/ M anipulation | \*---------------------------------------------------------------------------*/ Build : 10-c4cf895ad8fa Exec : interFoam -parallel Date : Nov 02 2023 Time : 21:57:12 Host : "dheaputri-IdeaPad-5-14ARE05" PID : 14056 I/O : uncollated Case : /home/dheaputri/Documents/coba_openfoam/DTCHullWave nProcs : 6 Slaves : 5 ( "dheaputri-IdeaPad-5-14ARE05.14057" "dheaputri-IdeaPad-5-14ARE05.14058" "dheaputri-IdeaPad-5-14ARE05.14059" "dheaputri-IdeaPad-5-14ARE05.14060" "dheaputri-IdeaPad-5-14ARE05.14061" ) Pstream initialised with: floatTransfer : 0 nProcsSimpleSum : 0 commsType : nonBlocking polling iterations : 0 sigFpe : Enabling floating point exception trapping (FOAM_SIGFPE). fileModificationChecking : Monitoring run-time modified files using timeStampMaster (fileModificationSkew 10) allowSystemOperations : Allowing user-supplied system call operations // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // Create time Create mesh for time = 0 Selecting fvMeshMover motionSolver Selecting motion solver: rigidBodyMotion Selecting rigidBodySolver Newmark --> FOAM Warning : From function Foam::labelHashSet Foam::polyBoundaryMesh::patchSet(const Foam::UList<Foam::wordRe>&, bool, bool) const in file meshes/polyMesh/polyBoundaryMesh/polyBoundaryMesh.C at line 834 Cannot find any patch or group names matching hull PIMPLE: No convergence criteria found CAN YOU PLEASE HELP ME... |
