#codeStram error: ill defined primitiveEntry starting at keyword 'internalField'
hello,
I am extremely new to OpenFOAM, I'm trying to make a simulation of Spinodal decomposition of Benchmark with OpenFoam.I use #codeStream to write the initial conditions under 0 files. This is my codes: /*--------------------------------*- C++ -*----------------------------------*\ ========= | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox \\ / O peration | Website: https://openfoam.org \\ / A nd | Version: 9 \\/ M anipulation | \*---------------------------------------------------------------------------*/ FoamFile { format ascii; class volScalarField; object c; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // dimensions [0 0 0 0 0 0 0]; internalField #codeStream { codeInclude #{ #include "fvCFD.H" #}; codeOptions #{ -I$(LIB_SRC)/finiteVolume/lnInclude \ -I$(LIB_SRC)/meshTools/lnInclude #}; codeLibs #{ -lmeshTools \ -lfiniteVolume #}; code #{ const IOdictionary& d = static_cast<const IOdictionary&>(dict); const fvMesh& mesh = refCast<const fvMesh>(d.db()); const scalar c_0=0.5; const scalar epsilon=0.01; scalarField c(mesh.nCells(),0.); forAll(c,i) { scalar x = mesh.C()[i][0]; scalar y = mesh.C()[i][1]; c[i] = c_0 + epsilon * ( cos(0.105 * x) * cos(0.11 * y) + pow(cos(0.13 * x) * cos(0.087 * y), 2) + cos(0.025 * x - 0.15 * y) * cos(0.07 * x - 0.02 * y)); } #}; } boundaryField { bottom { type zeroGradient; } top { type zeroGradient; } left { type zeroGradient; } right { type zeroGradient; } frontAndBack { type empty; } } // ************************************************** *********************** // When i run my case my terminal gives: FOAM FATAL IO ERROR: "ill defined primitiveEntry starting at keyword 'internalField' on line 18 and ending at line 88" file: /home/cxy/OpenFOAM/cxy-9/run/Benchmark/cavity/0/c at line 88. I checked multiple times but i don't find anything wrong and also my file is 84 lines long. Please, help me to figure out this. Many thanks. |
Anybody help? I need you! Thank you 3000 times~
