problem about CL>0 of a race car
Old   June 19, 2024, 06:32
Default problem about CL>0 of a race car
Federico Vegetti
Federico Vegetti is on a distinguished road
I've performed an incompressible RANS simulaztion with simpleFoam of a race car but i get a CL>0 and I don't know why.
Looking at the results it seems that the CL(f) is positive and generally higher in modulus with respect to CL(r).
I didn't performed mesh convergence, the mesh is only 2 milions of cells but I expected a result quite different from the current one.
I provide the slice of a section of the car with pressure field visible and the system folder.
I hope someone can help me.
Thanks you in advice.
Federico Vegetti is offline   Reply With Quote
Old   June 21, 2024, 06:55
Martin_Sz's Avatar
Marcin
Martin_Sz is on a distinguished road
A positive lift coefficient (CL>0) in your incompressible RANS simulation with simpleFoam for a race car indicates that the simulation is capturing some force acting upwards on the car. Here are some potential reasons why this might be happening and troubleshooting steps you can take:
1. Geometric Errors:
* Double-check your race car geometry for any inconsistencies or imperfections that might be causing an asymmetrical pressure distribution leading to lift. Ensure the car's underbody and wing are modeled accurately.
2. Boundary Conditions:
* Verify that the pressure boundary conditions are set correctly, especially for the ground plane. The pressure at the ground plane should be set to static pressure, not zero pressure.
3. Mesh Issues:
* While you haven't performed mesh convergence, a coarse mesh with only 2 million cells might not capture the flow details around the car accurately. Refining the mesh, particularly near the car's underbody and wings, can improve the results.
4. SimpleFoam Limitations:
* SimpleFoam is a basic RANS solver and might not be ideal for complex aerodynamic simulations involving race cars. Consider using a more advanced turbulence model or solver designed for external aerodynamics.
Troubleshooting Steps:
* Refine your mesh and check if the lift coefficient converges to a more reasonable value.
* Simulate a simpler bluff body case (e.g., a box) with simpleFoam and validate your setup against known results to ensure it's working correctly.
* Explore using a more advanced RANS solver or a detached-eddy simulation (DES) approach for better accuracy in race car aerodynamics.
If you can share more details about your setup, such as the specific boundary conditions and meshing strategy, it might be possible to provide more specific guidance.
Quick Tips and Tricks, Tutorials FLuent/ CFX (CFD)
https://howtooansys.blogspot.com/
Martin_Sz is offline   Reply With Quote
HELPP!!! CFD for FSAE race car djstoneage Main CFD Forum 2 July 13, 2023 16:45
fluent solver setting for external aerodynamics on a race car. Ahmed Jamal FLUENT 5 March 26, 2016 03:13
Radiation problem for car model aero FLUENT 1 February 3, 2007 23:30
New topic on same subject - Flow around race car Tudor Miron CFX 15 April 2, 2004 06:18
How can CFD be used to improve race car? A Chu FLUENT 1 February 8, 2004 20:21
