vahid
Rep Power: 3 ![]() |
I have completed a dense flow project using OpenFOAM version 11, but now when I want to run the file with OpenFOAM version 6, I get the following error in the blockMesh section. Does anyone know the reason for this and how to fix it? Thank you /*---------------------------------------------------------------------------*\ ========= | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox \\ / O peration | Website: https://openfoam.org \\ / A nd | Version: 6 \\/ M anipulation | \*---------------------------------------------------------------------------*/ Build : 6-47517f2ebb1b Exec : blockMesh Date : Nov 27 2024 Time : 04:38:50 Host : "vahid" PID : 6438 I/O : uncollated Case : /home/vahid/ffff/2/2 nProcs : 1 sigFpe : Enabling floating point exception trapping (FOAM_SIGFPE). fileModificationChecking : Monitoring run-time modified files using timeStampMaster (fileModificationSkew 10) allowSystemOperations : Allowing user-supplied system call operations // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // Create time --> FOAM Warning : From function virtual void Foam::Time::readDict() in file db/Time/TimeIO.C at line 405 Reading "/home/vahid/ffff/2/2/system/controlDict" from line 18 to line 74 Selecting compressed binary is inefficient and ineffective, resetting to uncompressed binary Creating block mesh from "/home/vahid/ffff/2/2/system/blockMeshDict" Creating block edges No non-planar block faces defined Creating topology blocks Creating topology patches Creating block mesh topology --> FOAM Warning : From function Foam: ![]() ![]() in file meshes/polyMesh/polyMeshFromShapeMesh.C at line 871 Found 34 undefined faces in mesh; adding to default patch. Check topology Basic statistics Number of internal faces : 18 Number of boundary faces : 48 Number of defined boundary faces : 48 Number of undefined boundary faces : 0 Checking patch -> block consistency Creating block offsets Creating merge list . Creating polyMesh from blockMesh Creating patches Creating cells Creating points with scale 1 Block 0 cell size : i : 0.000171968 .. 0.00497727 j : 0.000255388 .. 0.000255388 k : 0.000291871 .. 0.0036 Block 1 cell size : i : 0.00618056 .. 0.00618056 j : 0.000255388 .. 0.000255388 k : 0.000291871 .. 0.0036 Block 2 cell size : i : 0.000255388 .. 0.000255388 j : 0.000144102 .. 0.000144102 k : 0.000291871 .. 0.0036 Block 3 cell size : i : 0.000255388 .. 0.000255388 j : 0.000144102 .. 0.000144102 k : 0.000291871 .. 0.0036 Block 4 cell size : i : 0.000255388 .. 0.000255388 j : 0.000144102 .. 0.000144102 k : 0.000291871 .. 0.0036 Block 5 cell size : i : 0.000144102 .. 0.000144102 j : 5.73088e-05 .. 5.73088e-05 k : 0.000291871 .. 0.0036 Block 6 cell size : i : 0.00118197 .. 0.000208938 j : 0.000255388 .. 0.000255388 k : 0.000291871 .. 0.0036 Block 7 cell size : i : 0.000171968 .. 0.00497727 j : 0.000255388 .. 0.000255388 k : 0.000291871 .. 0.0036 Block 8 cell size : i : 0.00618056 .. 0.00618056 j : 0.000255388 .. 0.000255388 k : 0.000291871 .. 0.0036 Block 9 cell size : i : 0.000255388 .. 0.000255388 j : 0.000144102 .. 0.000144102 k : 0.000291871 .. 0.0036 Block 10 cell size : i : 0.000255388 .. 0.000255388 j : 0.000144102 .. 0.000144102 k : 0.000291871 .. 0.0036 Block 11 cell size : i : 0.000255388 .. 0.000255388 j : 0.000144102 .. 0.000144102 k : 0.000291871 .. 0.0036 Block 12 cell size : i : 0.000144102 .. 0.000144102 j : 5.73088e-05 .. 5.73088e-05 k : 0.000291871 .. 0.0036 Block 13 cell size : i : 0.00118197 .. 0.000208938 j : 0.000255388 .. 0.000255388 k : 0.000291871 .. 0.0036 Killed |
# openfoamv11, #blockmeshdict, #openfoam, #openfoam #error, #openfoamv6 |
Display Modes | |
[blockMesh] blockMesh with double grading. | spwater | OpenFOAM Meshing & Mesh Conversion | 92 | January 12, 2019 09:00 |
OpenFOAM without MPI | kokizzu | OpenFOAM Installation | 4 | May 26, 2014 09:17 |
[swak4Foam] groovyBC: problems compiling: "flex: not found" and "undefined reference to ..." | sega | OpenFOAM Community Contributions | 12 | February 17, 2010 09:30 |
Installation OF1.5-dev | ttdtud | OpenFOAM Installation | 46 | May 5, 2009 02:32 |
Problem with compile the setParabolicInlet | ivanyao | OpenFOAM Running, Solving & CFD | 6 | September 5, 2008 20:50 |
