Wall Shear Stress (WSS) in a Straight Circular Pipe Using simpleFoam
Like Tree4Likes
Old   February 5, 2025, 23:26
Yoshiki
Yoshiki is on a distinguished road
Thanks, Alczem and Severus!
Originally Posted by Yoshiki View Post
Also, when pFinal and UFinal were set to 1e-2 and 1e-3 respectively, the analysis converged in 114 iterations, and the results were almost the same as those obtained from a 1000-iteration analysis
without setting
residualControl
        p               1e-2;
        U               1e-3;
At that time I had mistakenly set final residual and residualControl, and it was that the convergence was faster when I set the residualControl as above. Sorry for the confusion.
solvers
    p
        solver          GAMG;
        smoother        GaussSeidel;
        tolerance       1e-7;
        relTol          0.01;
    pFinal
        $p;
        tolerance       1e-06;
        relTol          0;
    Phi
        $p;
    U
        solver          smoothSolver;
        tolerance       1e-8;
        relTol          0.1;
        nSweeps         1;
    k
        tolerance       1e-8;
        relTol          0.1;
        nSweeps         1;
    omega
        tolerance       1e-8;
        relTol          0.1;
        nSweeps         1;
SIMPLE
    nNonOrthogonalCorrectors 0;
    consistent yes;
    residualControl
        p               1e-2;
        U               1e-3;
Switching to the topic of flow velocity, the centreline velocity remained nearly unchanged: 0.419207 m/s at the inlet cross-section, 0.419172 m/s at the central cross-section along the length (z = 0.025), and 0.419164 m/s at the outlet cross-section.
Additionally, the velocity at the first cell center from the wall was 0.00255349 m/s at the inlet cross-section and 0.00251653 m/s at the central cross-section along the length.Switching to the topic of flow velocity, the centreline velocity remained nearly unchanged: 0.419207 m/s at the inlet cross-section, 0.419172 m/s at the central cross-section along the length (z = 0.025), and 0.419164 m/s at the outlet cross-section.
Additionally, the velocity at the first cell center from the wall was 0.00255349 m/s at the inlet cross-section, 0.00251653 m/s at the central cross-section along the length, and 0.003844769 m/s at the outlet cross-section, where it was noticeably higher.
Additionally, the wall shear stress at the inlet varies depending on the location and is lower than the theoretical value. This also occurs when a uniform flow is introduced into a straight circular pipe with a 0.4 m development section.
I am considering using ParaView's features to investigate how wall shear stress is calculated based on the gradient.
Alczem likes this.
Yoshiki is offline   Reply With Quote
openfoam2112, wall shear stress
[snappyHexMesh] How to draw a 3D-Drawing for Meshing Kahnbein.Kai OpenFOAM Meshing & Mesh Conversion 4 June 15, 2021 12:16
Ansys CFD-Post Application Error rushiCFD FLUENT 0 March 21, 2021 07:51
Calculating the Wall Shear Stress Gradient over surface 123catty456 Main CFD Forum 1 October 1, 2012 22:27
Terrible Mistake In Fluid Dynamics History Abhi Main CFD Forum 12 July 8, 2002 09:11
Flux depending on wall shear stress in Fluent 5.2 Andreas Borg FLUENT 0 June 7, 2000 06:27
