How can I use openFOAM to run wind tunnel simulation on F1 diffuser? |
Rep Power: 0 ![]() |
Hi all!
I am a machine learning engineer, currently working on a personal project on the intersection of geometric deep learning and aerodynamics. To that end, the workflow I have on my mind is the following: 1. Starting with a diffuser's geometry (STL file or similar). 2. Running a wind tunnel simulation to extract aerodynamic performance data (e.g., pressure, velocity). What I've done so far: 1. I got the diffuser from this model https://www.simscale.com/forum/t/per...-project/28931 and exported the STL file 2. I am in the process of learning openFOAM and understand how to import the STL file and run the simulation. Could someone provide a walkthrough? Thank you! |
Rep Power: 16 ![]() |
Do you have any previous experience in CFD modelling? If not, I'd suggest that you find a simpler topic ... unless you're prepared to spend a 3 yr apprenticeship learning the basics of CFD. OpenFOAM is not like a calculator where you can just pick it up, press some buttons and get an answer out. It is like a carpenter's toolboox, i.e. a bunch of tools that can generate excellent results in expert hands, but will generate junk otherwise.
Thank you for the answer!
![]() I really don't mind spending time learning the fundamentals. Do you know of any sources I can start from? I don't have CFD experience. My BSc is in informatics, and I will be defending my PhD within 2025. While working on my PhD I have also worked for Big4, startup and scale-up companies. My specialization is machine learning (ML). It's important for me to start learning about aerodynamics - and probably ICEs - specific to motorsports, while finding ways to combine them with computer science, and more specifically ML. |
aerodynamic analysis, machine learning |
Display Modes | |
OpenFOAM benchmarks on various hardware | eric | Hardware | 864 | May 25, 2025 15:53 |
Pitsco Airtech 40ic wind tunnel manual & software needed | Q-Prof | Main CFD Forum | 2 | May 15, 2019 13:26 |
Why my simulation not agree with the wind tunnel experiment | zhaowei | CFX | 4 | July 11, 2015 03:36 |
Suggestion for a new sub-forum at OpenFOAM's Forum | wyldckat | Site Help, Feedback & Discussions | 20 | October 28, 2014 09:04 |
Wind Tunnel Simulation: How to measure the downforce? | luckyrob | STAR-CCM+ | 14 | September 8, 2014 12:34 |
