FAN Boundary Condition problem with uniform jump and velocity vectors
Old   February 7, 2025, 16:24
Default FAN Boundary Condition problem with uniform jump and velocity vectors
Brayan Manuel Guerrero Martinez
BGM28 is on a distinguished road
I'm having troubles using the BC Fan condition to simulate a pressure jump with cyclic patches. As you can see the BC is applying a non-uniform jump and the velocity vectors are spinning around the BC. I need that pressure jump drive the entire flow at a positive Y velocity in an uniform manner using the curve's performance fan. I already changed the signs on the curve and the problems still appears even with a constant value pressure the flow is spinning. I don't know what's my problem.
If anyone can help me I would appreciate it. If you need more info don't dude to ask
The p-rgh surface is the BC cyclic Fan
This is my createBaffles script:
internalFacesOnly true;
// Baffles to create.
baffles
    cyclicFaces
        //- Select faces and orientation through a searchableSurface
        type        searchableSurface;
        surface     rotatedBox;
        origin    (0.150833 0.0201268 0.00700523); // P1
        e1         (0 0 -0.01472361);              // (P1 P3)
        e2         (0 -2e-5 0);                    //
        e3         (-0.002721 0 0);                // P1 P2)
        span       (0.01472361 2e-5 0.002721);     // (|e1|, |e2|, |e3|)
        patchPairs
            type            cyclic;
            // Optional override of added patchfields
            patchFields
                p_rgh
                    type            fan;
                    patchType       cyclic;
                    jumpTable       polynomial
                    2((-32.959 0)(4.8621 1));
                    uniformJump true;
                    value uniform -32.959;
                    outOfBounds     clamp;
                    jump            uniform -32.959 ;
This is my p_rgh script part related to the FAN with its curve's performance
    cyclicFaces_master
        type            fan;
        patchType       cyclic;
        jump            uniform 0;
            2
            (-32.959 0)
            (4.8621 1)
        uniformJump     true;
    cyclicFaces_slave
        type            fan;
        patchType       cyclic;
        value           uniform 0;
        uniformJump     true;
BGM28 is offline   Reply With Quote
fan boundary condition, openfoam, pressure jump
System with Fan Boundary Condition and an Inlet with Certain Value of Velocity with ryds9090 FLUENT 0 February 3, 2025 03:34
Simulation of an Actuator Disk - Question about Fan Boundary Condition Waketraveller FLUENT 3 June 15, 2022 17:25
Fan boundary condition using Ansys Fluent bhat_nikhil CFD Freelancers 0 November 24, 2020 11:22
Unexpected jump in Velocity & Temp across shock using pisoCentralFoam &rhoCentralFoam chirag OpenFOAM Verification & Validation 29 July 14, 2017 10:10
Velocity jump boundary condition ASofia OpenFOAM Programming & Development 0 July 14, 2016 10:01
