Unrealistic velocity and pressure result in DPMFoam
Old   February 14, 2025, 04:26
Unhappy Unrealistic velocity and pressure result in DPMFoam
Rundeli is on a distinguished road
Hello all:
I am trying to set up a 3D numerial water channel which contains particles in the middle part using DPMFoam v2412.
My case setup is as follows:
0/U.water:
internalField   uniform (0 0 0);
boundaryField
    bottom
        type            noSlip;
    top
       type            noSlip;
    inlet
        type            fixedValue;
        value           uniform (5 0 0);
    outlet
        type            zeroGradient;
    frontAndBack
        type            symmetry;
0/p:
internalField   uniform 0;
boundaryField
    inlet
        type            fixedFluxPressure;
        phi             phi.water;
        value           $internalField;
    bottom
        type            zeroGradient;
    top
        type            zeroGradient;
    outlet
        type            fixedValue;
        value           uniform 0;
    frontAndBack
        type            symmetry;
constant/kinematicCloudProperties:
solution
    active          true;
    coupled         true;
    transient       yes;
    cellValueSourceCorrection on;
    interpolationSchemes
        rho.water         cell;
        U.water           cellPoint;
        mu.water          cellPoint;
        DUcDt             cellPoint;
    integrationSchemes
        U            Euler;
    sourceTerms
        schemes
            U semiImplicit 1;
constantProperties
    parcelTypeId 1;
    rhoMin          1e-15;
    minParcelMass   1e-15;
    rho0            2526;
    youngsModulus   5e6;
    poissonsRatio   0.45;
    constantVolume  false;
    alphaMax        0.9;
subModels
    particleForces
        ErgunWenYuDrag
            alphac alpha.water;
        gravity;
    injectionModels
        model1
            type            manualInjection;
            massTotal       0;
            parcelBasisType fixed;
            nParticle       1;
            SOI             0;
            positionsFile   "kinematicCloudPositions";
            U0              (0 0 0);
            sizeDistribution
                type        fixedValue;
                fixedValueDistribution
                    value   0.0004;
    packingModel none;
    dispersionModel none;
    patchInteractionModel multiInteraction;
    multiInteractionCoeffs
        oneInteractionOnly false;
        model1
            patchInteractionModel localInteraction;
            localInteractionCoeffs
                patches
                    "(bottom|frontAndBack|top)"
                        type rebound;
                        e 0.91;
                        mu 0.17;
                    "(outlet|inlet)"
                        type none;
        model2
            patchInteractionModel periodInteraction;
            periodInteractionCoeffs
                recyclePatches
                    (inlet outlet)
                recycleFraction 1;
    surfaceFilmModel none;
    collisionModel pairCollision;
    pairCollisionCoeffs
        maxInteractionDistance  0.0002;
        writeReferredParticleCloud no;
        pairModel pairSpringSliderDashpot;
        pairSpringSliderDashpotCoeffs
            useEquivalentSize   no;
            alpha               0.02;
            b                   1.5;
            mu                  0.10;
            cohesionEnergyDensity 0;
            collisionResolutionSteps 12;
        wallModel wallSpringSliderDashpot;
        wallSpringSliderDashpotCoeffs
            youngsModulus   1e10;
            poissonsRatio   0.23;
            alpha           0.01;
            b               1.5;
            mu              0.09;
        U     U.water;
    stochasticCollisionModel none;
cloudFunctions
with timestep of 5e-7 and this is the result of 1e-5 which is clearly not realistic.
velocity field with particles:
velocity field:
pressure field:
what is wrong with my case setup ?
Rundeli is offline   Reply With Quote
dpmfoam, lagrangian, water channel
Generate convective pressure fluctuation Bananenflanke CFX 10 May 12, 2021 19:33
Import .csv - velocity profile - error eSKa CFX 9 April 3, 2021 14:38
Specify both velocity and pressure at inlet boundary NOD STAR-CCM+ 4 March 7, 2021 07:36
Multiphase flow - incorrect velocity on inlet Mike_Tom CFX 6 September 29, 2016 02:27
the result of the velocity and pressure drop is a little strange. yuhehuan FLUENT 0 December 18, 2012 20:48
