[Sponsors] | |||||
Temperature keep rising in chtMultiRegionSimpleFoam |
Jalalludin Mukhtafi
Rep Power: 0 ![]() |
Hello everyone,
I’m new to OpenFOAM and currently have an issue modeling power generation in a reactor using the scalarSemiImplicitSource function. The simulation is run in steady state with the internal values for both solid and fluid set to 1023 K. Then, in each reactor pin I apply the Su & SpX terms of the scalar semi-implicit source, where I vary Su between 1e7 W/m³ and 1 W/m³, while SpX follows a cosine function as shown in the figure below. Each fuel pin has a volume of 0.0275 m³, and for the 1:12 reactor model I’m using, the total volume is 0.687 m³. The result in the 1:12 reactor simulation shows that the temperature keeps rising above 2000 K, whereas in the single-pin simulation the temperature is around 1400 K. Should I reduce the Su value so that the temperature in the 1:12 model can drop to around 1400 K? However, I don’t think that’s the real solution, because even when I try with Su = 1 W/m³, the temperature still blows up to 2000 K. It seems that this is influenced by the SpX value?
#2 | |
HLX
Rep Power: 2 ![]() |
Actually, you can calculate it (heat transfer equation) |
| Tags |
| chtmultiregionsimplefoam, heattransfer, openfoam, reactor, steadystate |
| Thread Tools | Search this Thread |
| Display Modes | |
| Thread | Thread Starter | Forum | Replies | Last Post |
| [openSmoke] libOpenSMOKE | Tobi | OpenFOAM Community Contributions | 562 | January 25, 2023 10:21 |
| Shadow Wall and temperature | norger | FLUENT | 10 | September 28, 2019 12:43 |
| Outlet temperature to temperature boundary condition of velocity inlet. (UDF) | dillon | Fluent UDF and Scheme Programming | 3 | March 25, 2018 12:06 |
| How to get free stream temperature in boundary condition | saharesobh | FLUENT | 0 | October 9, 2012 18:12 |
| Inlet won't apply UDF and has temperature at 0K! | tccruise | Fluent UDF and Scheme Programming | 2 | September 14, 2012 07:08 |
