Two questions concerning formatting and structure |
May 23, 2008, 12:40 |
Dear Maintainers,
Good even
Daniel WEI (老魏)
Rep Power: 21 |
Dear Maintainers,
Good evening! 1. How to post double spaces? it's annoying every time I tried to post some code, many spaces are shorten to one space! 2. Can the topic structure be modified to a more detailed way. eg., devided OpenFOAM Message Board: OpenFOAM: Installation into Installation--Windows; Installation--Linux; Installation--Mac; Installation--Unix; ... or some places for dummy. Daniel
~ Daniel WEI ------------- Boeing Research & Technology - China Beijing, China |
May 23, 2008, 19:42 |
Hi Daniel,
@1: I use
Takuya OSHIMA
Rep Power: 20 |
Hi Daniel,
@1: I use <pre> - </pre> tags to format code retaining indents as in this post. You have to escape closing brace (}) with a prepending \ (i. e. "\}"). This seems to be an undocumented feature by the way. Takuya |
May 23, 2008, 20:48 |
Great! Thank you, Takuya. Here
Daniel WEI (老魏)
Rep Power: 21 |
Great! Thank you, Takuya. Here's a test.
<pre>...... if (bufferSizeName.size()) { int bufferSize = atoi(bufferSizeName.c_str()); if (bufferSize) { MPI_Buffer_attach(new char[bufferSize], bufferSize); } } else { FatalErrorIn("Pstream::init(int& argc, char**& argv)") << "Pstream::init(int& argc, char**& argv) : " << "environment variable MPI_BUFFER_SIZE not defined" << Foam::abort(FatalError); } # endif ......</pre> Daniel
FVM for structure | Raj | Main CFD Forum | 1 | October 19, 2008 08:32 |
help with udf structure | rana | FLUENT | 3 | December 14, 2007 05:06 |
structure won't appear | wan UNIMAP | CFX | 3 | December 13, 2007 16:16 |
Structure of CFD code | Shyam | Main CFD Forum | 5 | April 26, 2006 12:04 |
