Network hardware used in clusters
Old   May 25, 2008, 09:32
Default Hello, I'm interested in what
kar
Kārlis Repsons
kar is on a distinguished road
I'm interested in what kind of networking people use for effective parallel CFD computing? When it is sufficient with some cat5 wiring + switches and when something faster, like Infiniband is necessary?
Regards,
Kārlis
kar is offline   Reply With Quote
Old   May 25, 2008, 11:23
Default It is strongly application and
BastiL
bastil is on a distinguished road
It is strongly application and code-dependend. As a rute of thumb:
For calculations on more than 16 cpus "normal" gigabyte ethernet is too slow mostly. Nevertheless it is also dependend on number of cores per node,...
Regards
bastil is offline   Reply With Quote
Old   May 25, 2008, 16:41
Default You mean > 16core machine?? El
kar
Kārlis Repsons
You mean > 16core machine?? Else it makes some kind of nonsense to me - switch should be able to handle properly all of it's connects, isn't that right?
Old   May 25, 2008, 17:35
Default I do not understand what you m
BastiL
I do not understand what you mean. Of course a switch can handle all. However, if you distribute a CFD case into more than about 16 parts communication overhead grows non-linear. That means for these cases with that much communication your network will definitely be the first bottleneck in cases of speed. This is refered to as speedup. If you run a case on one core you get a speedup of one. Running it on eg 8 cores has a theoretical speedup of 8 but you will only get less. And using gigabyte ethernet you will not get much quicker if you use 16 or 32 or 64 codes in general - of course this is case and architecture dependend. However using faster interconnects (eg infiniband) will give you further speedup if you switch from 16 to 32 parts... This is what I wanted to say.
All this is also dependend on number of cores per CPU and CPUs per node. Above numbers go for typical nodes with 2CPUs and 2 cores per CPU. I do not know to much about nodes with more cores on it...
Old   May 26, 2008, 05:18
Default So the story is about timestep
kar
Kārlis Repsons
So the story is about timestep computing time compared with time necessary to exchange boundary values. Gigabyte network might have two speed problems: too little transfer speed and latencies. By dividing, typical timestep computing time and speedup decreases, if network is slower than inter-core communication.
Just curious: how much those infiniband NIcards cost? And ~30 port switch?
Old   May 26, 2008, 17:46
Default And please don't forget to fac
Srinath Madhavan (a.k.a pUl|)
msrinath80 is on a distinguished road
And please don't forget to factor in the memory bandwidth bottleneck when using multi-core CPUs. The more cores that share memory bandwith, the worse is the speedup (even if onboard core interconnects are used).
msrinath80 is offline   Reply With Quote
CFD clusters + bonded GigE? Joe Main CFD Forum 8 September 19, 2006 08:58
Clusters on linux: PVM vs. HP MPI Alexey CFX 4 February 8, 2006 11:33
Best CFX Platform for developing clusters Javier O. Augusto CFX 0 August 25, 2005 13:09
MPI on Clusters wak Siemens 0 September 19, 2004 23:03
Beowulf clusters Sebastien Perron Main CFD Forum 18 May 17, 2001 19:11
