Firewall settings bproc distributed file syntax |
January 12, 2008, 02:32 |
I've recently been exp
Michael Jaworski
I've recently been exploring the distributed networking options of OpenFOAM and I have three questions: 1. does anyone have a firewall setup that works with openMPI stuff? I'm hesitant to shut the firewall off, but I don't know the steps to setting it up correctly (using OpenSUSE 10.3). 2. What sort of speed-up has anyone seen with bproc stuff? any? is it worth it? 3. The manual seems a little scant on how to set up the cases for distributed vs. non. if I have 2 dual-core processors on 2 computers, how many root directories do I specify, or, if they're the same, is this even needed? Also, what is the speed-up, if any, of choosing distributed computing? With regards to 3, I'd be happy to test this on my own, but when I set distributed yes, roots 2 ( /home/mjaworsk/..../interFOAM /home/....same....) interFOAM yelled at me with improper syntax on those lines. what does it really want there? when I set it to "no", it ran fine across both computers. Thanks for any help on these, Mike |
January 14, 2008, 07:01 |
3. per process in your paralle
Mattijs Janssens
Rep Power: 26 |
3. per process in your parallel run you'll have to specify a directory. So e.g. mpirun -np 4 means you need 4 roots. Even if all processes are on the same processor or core or whatever.
January 14, 2008, 11:46 |
Hi Mattijs,
Thanks for th
Michael Jaworski
Hi Mattijs,
Thanks for the note. I added all four lines and I had been missing some quotation marks. It's running now. Thank you much. -Mike |
Interpolation command '-interp-iv' in syntax file | KM | CFX | 4 | October 12, 2007 17:29 |
journal file syntax / selecting all surf in one go | Jean-Francois | FLUENT | 0 | February 23, 2006 11:57 |
Syntax | r2d2 | OpenFOAM | 1 | December 13, 2005 14:19 |
MPICH and FireWall with XP | xc | FLUENT | 0 | August 16, 2005 19:45 |
changing settings.pcl file | R P | CFX | 3 | October 15, 2004 03:55 |
