Line 140 make command not found What is the solution |
November 12, 2006, 15:25 |
Hi
while I try to compile cod
Faroque Hossain
Rep Power: 17 |
Hi
while I try to compile code with wmake I am getting following error msg. + wmake mhdFoam /home/faroque/OpenFOAM/OpenFOAM-1.3/wmake/wmake: line 140: make: command not found /home/faroque/OpenFOAM/OpenFOAM-1.3/wmake/wmake: cannot make, file Make/linuxGcc4DPOpt/objectFiles was not created successfully does anyone have any idea how to solve this problem? Thanks in advance. -- Faroque |
November 13, 2006, 04:16 |
Do you have 'make'? I have
Mattijs Janssens
Rep Power: 26 |
/usr/bin/make To compile OpenFOAM you will need a full development installation on your system ('make', 'ld', 'as'). You can usually install these from your operating system disk. |
[OpenFOAM] ParaView command not found | joey | ParaView | 12 | January 18, 2021 05:38 |
[OpenFOAM] Paraview command not found | hardy | ParaView | 7 | September 18, 2008 04:59 |
Problem of compilation OF 14Allwmake command not found | erik_d | OpenFOAM Bugs | 13 | September 13, 2008 21:45 |
Bash g command not found | mamaly60 | OpenFOAM Installation | 0 | October 18, 2007 17:14 |
Error starting paraFoam line 67 paraview command not found | jango | OpenFOAM Installation | 4 | July 19, 2007 01:39 |
