Environmental open channel sediment transport |
April 1, 2005, 16:13 |
I just recently have looked in
owen ransom
I just recently have looked into OpenFOAM to try and solve problems for open channel flow. My hope is to apply this to modeling transport in sinuous channels. I was curious if there was anyone else interested in the same area, to perhaps give me some pointers, as I am just learning.
April 4, 2005, 05:32 |
There is a code called settlin
Eugene de Villiers
Rep Power: 21 |
There is a code called settlingFoam that has some sedimentation-type capabilities. Run the tutorial and see if it fits your needs.
For free-surface flow you will probably need a VOF two-phase solver. See rasInterFoam for an example of this. |
June 27, 2005, 12:40 |
Hi Owen,
I would like to kn
Billy
Hi Owen,
I would like to know if you have applied OpenFOAM to sediment transport. I am also interested in modelling sediment transport and erosion. |
June 29, 2005, 14:11 |
Hi Owen and Billy,
I've studi
David Segersson
Hi Owen and Billy,
I've studied channel flow with other CFD codes than OpenFOAM. After what I've seen so far, you will probably be able to solve your problems in OpenFOAM. However, you will need to write some code yourself (inlet profiles, sedimentation and erosion is not implemented for channel flow). All the tools for doing this are available in OpenFOAM, you "just" have to put them together. An advice is not to use a VOF solver, even if it is tempting, unless you are primarily interested in the free surface over a quite limited part of the channel, such as a inlet to a dam (it requires a fine mesh close to the surface, and make the calculations much slower). Instead you could use a fixed surface with a symmetry boundary condition (maybe with some modifications to the turbulence model). In order to be able to cunstruct the mesh, you will have to know the position of the free surface in advance. Vegetation in the channel can be handled by introducing a drag term in the momentum equation, I'm trying to to that for land vegetation right now (wind simulations), and it will be ready quite soon (I hope). Regards David |
July 4, 2005, 18:00 |
Hi David,
Thanks for your i
Billy
Hi David,
Thanks for your input. Billy. |
June 30, 2010, 04:58 |
sediment transport equation
Malek
Have you succeed to implement transport sediment equation in Openfoam? because actually I'm working on it for my final year project. Give me a advice please how did you do it. Malek |
August 21, 2011, 10:03 |
bojiezhang
HI:
Have you succeed to imply transport sediment equation in Openfoam? Can you give me a advice and tell me how to do it. bojiezhang |
Free Surface Flow with Sediment Transport | M. Riffai | CFX | 3 | September 5, 2013 09:45 |
Using settlingFoam for sediment transport | amelia | OpenFOAM Running, Solving & CFD | 2 | August 21, 2011 09:15 |
Sediment transport (help) | thinlas | FLUENT | 3 | January 19, 2005 11:29 |
sediment transport | akbar | FLUENT | 0 | November 22, 2003 03:14 |
Re: Can I simulate sediment transport with FLUENT | li li | FLUENT | 0 | October 21, 2003 20:42 |
