April 27, 2009, 00:30 |
A free surface problem
crammer008
Rep Power: 16 |
Dear all,
I am a newbie. I'd like to simulate the following simple case. Would you please tell me where I can find a similar tutorial case to learn the modelling. The tested case is a 2D rectangular tank which is partially filled with water and will move with a sinusoidal signal. The measured data is the pressure response at a certain point and free-surface elevation at a certain vertical position. A laminar model is preferred for the case. Many thanks! Crammer008 |
April 27, 2009, 10:33 |
Kent Wardle
Rep Power: 21 |
Take a look at interDyMFoam, this should be what you need. There are several tutorials available for sloshing tanks as well to help you get started.
April 27, 2009, 22:41 |
crammer008
Rep Power: 16 |
Dear Kwardle,
Thanks a lot for your great help Best regards, LUO Chao |
Display Modes | |
UDF Defining VOF Free Surface at Outlet | Alex | Fluent UDF and Scheme Programming | 13 | August 8, 2012 17:50 |
Free Surface Position | Jennifer | CFX | 3 | November 17, 2008 02:51 |
Free surface modelling under CFX 4 | Dahong | CFX | 2 | June 23, 2002 00:07 |
CFX4.3 -build analysis form | Chie Min | CFX | 5 | July 13, 2001 00:19 |
sphere in a free surface (thin film)flow | Vasu Veerapaneni | Main CFD Forum | 0 | September 15, 1998 18:32 |
