recompilation OF 1.5 applications libstdc++.so
Hi all,
I have a problem recompiling OpenFOAM applications. The error message I keep getting is ---------------------- /home/pc/OpenFOAM/ThirdParty/gcc-4.3.1/platforms/linux64/bin/../lib/gcc/x86_64-unknown-linux-gnu/4.3.1/../../../../lib64/libstdc++.so: file not recognized: File format not recognized collect2: ld returned 1 exit status make: *** [/home/pc/OpenFOAM/OpenFOAM-1.5/applications/bin/linux64GccDPOpt/interFoam] Error 1 -------------------------- I run OpenSuSE + my gcc version is 4.3.1 on the home direc and the 4.3.1 that comes in Third Party software with OF Thanks a lot for your help! Jamba |
Same problem on Suse x64 with OpenFoam 1.6.x snapshot
Hello, as I am facing exactly the same problem on another platform and another OpenFoam version, I was wondering if you got an answer on this ?
My version : Linux 2.6.16.60-0.21-smp #1 SMP Tue May 6 12:41:02 UTC 2008 x86_64 x86_64 x86_64 GNU/Linux I get several times the folowing linkage error : gcc-4.3.3/platforms/linux64/bin/../lib/gcc/x86_64-unknown-linux-gnu/4.3.3/../../../../lib64/libstdc++.so: file not recognized: Format de fichier non reconnu collect2: ld returned 1 exit status Any clues anyone ? |
Greetings Arnaud,
There are multiple solutions for that problem. The main issue lies on a conflict of available tools, namely OpenFOAM's pre-built gcc 4.3.3 and (I'm guessing) openSUSE's gcc 4.4.1. Solution 1 - Swapping gcc 4.3.3 libraries for the system libraries - run these commands (advice: one by one, just in case... because none of them should complain with errors): Code:
cd ~/OpenFOAM/ThirdParty-1.6/gcc-4.3.3/platforms/linux/lib Solution 3 - Using the system's gcc 4.4.? - gcc-4.4 and above... post #7 Best regards, Bruno |
Well, no luck
Hello, thank you for your reply !
First point, my platform is not an OpenSuse but a Suse Enterprise 10.2 : Code:
> cat /etc/SuSE-release So as you can guess, I was using the compiler provided in Thirdparty (gcc 4.3.3)
In parallel, collegues are going to try compilation on the latest OpenSuse and if success we will migrate this "old" Suse Enterprise server to OpenSuse |
Greetings Arnaud,
OK, then might I suggest following the instructions at this thread, more specifically posts #13 and #18. Those posts have instructions to fix OpenFOAM's MPFR and a tweaked makeGcc script for strict x86_64 compiling of gcc :) The surrounding posts could also have vital information for you! And even if your SuSe box is a bit old, it can still crank up the speed on the latest OpenFOAM ;) Good luck and keep us posted on your efforts! Best regards, Bruno |
Hello again,
Well, things are in progress... Thanks for the redirection to previous post : this helped me a lot and I could successfully compile gcc 4.3.3 & co ! Currently, OpenFoam is being compiled (started a bit less than an hour ago, but still no errors, so I would say it's going better than before) In the meantime, I tried briefly to compile paraview but did get a "cmake not found" error : I'm going to check in previous posts if I can find a clue. I'l let you know how this goes |
Greetings Arnaud,
You can get a pre-built cmake from the 32 bit binary package of ThirdParty. Just unpack the file ThirdParty-1.6.linuxGcc.gtgz the same way you did the other packages, and you'll get cmake good to go... or so I hope. Well not quite, since you will also need to install a package that could be named ia32libs (it's the name in Ubuntu, I'm not sure what is its name in SuSe :() for it to run. It provides libraries for running 32 bit applications in 64bit Linux boxes. Or you could download the cmake source from www.cmake.org and build it. Paraview 3.6.1 needs at the very least "cmake 2.6.4". Also, you can follow this thread: New user needs help - it provides a very step-by-step on how to install Qt 4.3.5 + Paraview. Best regards, Bruno |
Well, we are progressing :
Now openfoam compiles successfully ! Great step forward ! Thanks for your help again ! Paraview compiles successfully too, I get the splash screen on start, but that's all : segmentation fault before anything else happens. |
I think your SuSe is running in French or similar. In other words, you possibly need the trick for forcing standard English:
export LC_ALL=C The second possibility, is that PV3FoamReader needs to be rebuilt. If it still crashes, another possibility is that there is a clash of loaded libraries. Try running paraview directly form it's binary folder "OpenFOAM/ThirdParty-1.6/paraview-3.6.1/platforms/linux64/bin/", but without the OpenFOAM environment being active/sourced! If it runs, the guilty party is library clashes. Somehow, OpenFOAM and Paraview probably weren't built with the same gcc version. Good luck! Bruno |
You reply too fast !
I had juste found previous messages from you on another post : http://www.cfd-online.com/Forums/ope...ion-fault.html => As it's a Suse french version, I tried the LC_LANG => no luck => I'm not sure if I used the system compiler ou openfoam's to compile paraview and saw this could have an effect => currently trying to fix this... and... yes, it works !!! Thanks again for all your help Best regards, Arnaud |
You're welcome :) I'm glad it's working now :)
