Parallel Moving Mesh Bug for Multi-patch Case |
May 21, 2009, 00:23 |
Cem Albukrek
Hello all,
I am testing the mesh motion for a simple case that consists of a rectangular block with 6 patches for 6 faces. I use pointMotionVelocity to drive the mesh motion. If I run a solver like "InterDyMFoam" on a single processor, everything runs right. However, if I decompose the case to 2 or more processors and continue the run in parallel then I get errors similar to the below. It seems the mesh.update() does not interpret the number of points to move on the patches distributed between the processors right. If I define the whole cube as a single patch and run it in parallel then I do not run into any issues. Some validation on whether this is a true bug and insight into resolving the issue would be helpful. Thanks Cem Exec : rasInterDyMFoam -parallel Date : May 20 2009 Time : 19:59:13 Host : PID : 8833 Case : nProcs : 2 Slaves : 1 ( goldenhorn.8834 ) Pstream initialized with: floatTransfer : 1 nProcsSimpleSum : 0 commsType : nonBlocking // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // Create time Create mesh for time = 0.01 Selecting dynamicFvMesh dynamicMotionSolverFvMesh Selecting motion solver: velocityLaplacian [1] [0] [0] [0] size 834 is not equal to the given value of 835 [0] [0] file: /MultiPatchCube/processor0/0.01/pointMotionU::Block_Side2 from line 3800 to line 3801. [0] [0] From function Field<Type>::Field(const word& keyword, const dictionary& dict, const label s) [0] in file /home/cae/OpenFOAM/OpenFOAM-1.5/src/OpenFOAM/lnInclude/Field.C at line 224. [0] FOAM parallel run exiting [0] [goldenhorn.caebridge.com:08833] MPI_ABORT invoked on rank 0 in communicator MPI_COMM_WORLD with errorcode 1 [1] [1] size 889 is not equal to the given value of 890 [1] [1] file: /MultiPatchCube/processor1/0.01/pointMotionU::Block_Bottom from line 1627 to line 1628. [1] [1] From function Field<Type>::Field(const word& keyword, const dictionary& dict, const label s) [1] in file /home/cae/OpenFOAM/OpenFOAM-1.5/src/OpenFOAM/lnInclude/Field.C at line 224. [1] FOAM parallel run exiting [1] [goldenhorn:08834] MPI_ABORT invoked on rank 1 in communicator MPI_COMM_WORLD with errorcode 1 mpirun noticed that job rank 1 with PID 8834 on node goldenhorn exited on signal 123 (Unknown signal 123). Last edited by albcem; May 22, 2009 at 01:11. |
Runing InterFoam for 3 D damBreak case Patch issue | nishant_hull | OpenFOAM Running, Solving & CFD | 5 | February 18, 2009 00:32 |
how to extend FSI 2D codes to 3D, need advises | abouziar | Main CFD Forum | 1 | May 30, 2008 04:08 |
[mesh manipulation] TranformPoints gives skewed mesh Possible Bug | andersking | OpenFOAM Meshing & Mesh Conversion | 3 | March 25, 2008 21:33 |
Free surface boudary conditions with SOLA-VOF | Fan | Main CFD Forum | 10 | September 9, 2006 12:24 |
Automatic Mesh Motion solver | michele | OpenFOAM Running, Solving & CFD | 10 | September 26, 2005 08:21 |
