movingConeMotion with "Floating point exception" crashed!! |
June 23, 2009, 06:52 |
quinton
hi,
i just compile the "setMotionMovingCone.C", everything is ok! when i run icoDyMFoam, the errors like this: Selecting dynamicFvMesh dynamicMotionSolverFvMesh Selecting motion solver: laplaceFaceDecomposition Selecting motion diffusivity: file Reading transportProperties Reading field p Reading field U Reading/calculating face flux field phi Reading field rAU if present Starting time loop Volume: new = 1.73779e-09 old = 1.73779e-09 change = 0 ratio = 0 Courant Number mean: 0 max: 0.3 velocity magnitude: 1 Time = 5e-06 Floating point exception what should i do!? thanks best regards! |
September 3, 2009, 19:56 |
Henrik Rusche
Rep Power: 18 |
Dear Quinton,
this issue is fixed in revision 1421. Best Regards, Henrik |
[blockMesh] BlockMeshmergePatchPairs | hjasak | OpenFOAM Meshing & Mesh Conversion | 11 | August 15, 2008 07:36 |
[Gmsh] Gmsh and samplesurface | touf | OpenFOAM Meshing & Mesh Conversion | 2 | December 10, 2007 02:27 |
