July 14, 2009, 08:02 |
lift and drag
Hi, I was searching the forum to find some help to get the lift and drag tool and I finally downloaded the files from the third post in this thread:
http://www.cfd-online.com/Forums/ope...ion-141-a.html I compiled and now it seems to be ok but I don't know what library i have to call in the controldict file :S Last edited by nicchani; July 14, 2009 at 10:24. |
July 14, 2009, 10:45 |
this is what I am using:
functions ( forces { type liftDrag; functionObjectLibs ("libincompressiblePostProcessing.so"); and when I run it I get this error: --> FOAM FATAL ERROR : Unknown functiont type liftDrag Valid functions are : 2 ( turbulentForceAndTorque laminarForceAndTorque ) From function functionObject::New(const word& functionType, const Time&, const dictionary&) in file db/functionObject/functionObject.C at line 89. FOAM exiting I don't know why the liftDrag function isn't valid. |
July 14, 2009, 11:10 |
Steve Hansel
I'm getting force and torque with this, although in the recent 1.5-dev there might be a problem with this library.
functions // this one! ( forces { type forces; functionObjectLibs ("libforces.so"); //Lib to load patches (turbine); // change to your patch name rhoInf 1.225; //Reference density for fluid CofR (0 0 0); //Origin for moment calculations } ); |
July 14, 2009, 11:26 |
I am using openfoam 1.4.1 so I don't have that library. If I use turbulentforceandtorque as a force I get some forces on the screen, but what I want is the lift and drag and I have no idea how to get it or if the forces I get on the screen are those. I don't even know what force and torque is. I'm obviously new at this
when I use turbulentforceandtorque I get these forces on screen: Pressure forces = 1((0 0 0)) Pressure moments = 1((0 0 0)) Viscous forces = 1((0 0 0)) Viscous moments = 1((0 0 0)) Total forces = 1((0 0 0)) Total moments = 1((0 0 0)) |
July 15, 2009, 07:01 |
I have an exe called liftDrag which I guess is the tool for postprocessing. I run the simulation with simplefoam and when it's finished I have run liftDrag but I get all these errors and I don't know what's the problem. Can someone help me with this please? Thanks.
Create mesh for time = 0 Time = 0 Reading U Reading p Inlet velocity: (73.45 0 0) Wall patch 0 named AEROFOIL : Reference area: 31082.9 Reference length: 500.232 Drag coefficient: 0 Lift coefficient: (0 0 0) Moment coefficient: (0 0 0) #0 Foam::error:rintStack(Foam::Ostream&) in "/home/nicky/OpenFOAM/OpenFOAM-1.4.1/lib/linuxGccDPOpt/libOpenFOAM.so" #1 Foam::sigFpe::sigFpeHandler(int) in "/home/nicky/OpenFOAM/OpenFOAM-1.4.1/lib/linuxGccDPOpt/libOpenFOAM.so" #2 Uninterpreted: [0xffffe420] #3 Foam::liftDrag::momentCoefficient(Foam::GeometricF ield<Foam::Vector<double>, Foam::fvPatchField, Foam::volMesh> const&, Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh> const&, Foam::dimensioned<double> const&, Foam::word const&, Foam::Vector<double> const&, double const&, double const&) in "/home/nicky/OpenFOAM/OpenFOAM-1.4.1/lib/linuxGccDPOpt/libincompressiblePostProcessing.so" #4 main in "/home/nicky/OpenFOAM/OpenFOAM-1.4.1/applications/bin/linuxGccDPOpt/liftDrag" #5 __libc_start_main in "/lib/i686/libc.so.6" #6 __gxx_personality_v0 in "/home/nicky/OpenFOAM/OpenFOAM-1.4.1/applications/bin/linuxGccDPOpt/liftDrag" Floating point exception |
July 20, 2009, 08:56 |
Hi everyone
I tried to use the function described in Hansel's post, but I get an error using it. Here is what's written in the log file : ************************************************** ***************** attempt to read beyond EOF file:..............................;/system/controlDict::functions at line 60. From function ITstream::read(token& t) in file db/IOstreams/Tstreams/ITread.C at line 64. FOAM exiting ************************************************** ******************* It seems that there's a library missing or smthg like that Any idea ? |
Correct lift but wrong pressure drag - possible? | zx | Main CFD Forum | 4 | July 27, 2007 23:38 |
Lift and Drag Coefficients Reliability | Luis | FLUENT | 2 | December 27, 2005 14:45 |
Drag and Lift | Daniel Fisher | Phoenics | 2 | April 8, 2005 03:51 |
drag and lift coefficient | Noé | Siemens | 5 | July 13, 2004 10:21 |
Fluid mechanics / drag & lift | Jamcam | Main CFD Forum | 0 | October 31, 2002 04:39 |
