change value of k in the solver dieselFoam
Old   July 21, 2009, 07:20
Default change value of k in the solver dieselFoam
Yejun Gong
yejungong is on a distinguished road
I want to change the value of k and epsilon in the solver, dieselFoam. But k and epsilon is initialized in turbulenceModel, and I only know how to read them. I tried to define a pointer pointing to k, and then change the value of k. The following is my code,
const tmp<volScalarField>& k=turbulence->k();
k +=
dieselSpray.turbulenceDepletionSource()*runTime.deltaT()/rho;
turbulenceDepletionSource() is defined in dieselSpray class as the source term for the k-equation, similar to momentum source term
But it didn't work. The error message is attached in the bottom. I tried to update it cell by cell, but failed either.
Any suggestions will be highly appreciated.
thanks a lot
Yejun
The following the error message,
dieselFoam.C: In function 'int main(int, char**)':
dieselFoam.C:89: error: passing 'const Foam::tmp<Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh> >' as 'this' argument of 'void Foam::tmp<T>:perator=(const Foam::tmp<T>&) [with T = Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh>]' discards qualifiers
yejungong is offline   Reply With Quote
Phase Change Application - Error in Solver Patrick CFX 2 June 28, 2016 09:49
segregated solver vrs coupled solver sm FLUENT 0 November 6, 2007 01:24
questions concerning solver and multigrid methodes youradvice Main CFD Forum 1 August 6, 2007 15:27
Coupled and Segregated solver soe FLUENT 2 March 8, 2007 04:37
Symmetry plane error in solver Santiago Orrego. CFX 6 January 31, 2007 07:09
