Loading geometry to OF 1.5
Old   July 22, 2009, 06:36
Default Loading geometry to OF 1.5
Paavo Mäkelä
pa-ma is on a distinguished road
Hi
I am very new to OpenFOAM and I'm not sure if I'm doing this the right way...
I want to load some geometry into OF which I modeled in Catia and added a bounding box to the .stl file in another cad package. Do you usually model a separate bounding box (ie. walls) or do you add this somehow later by editing something in /polyMesh/?
Anyway, I managed to mesh the model in Netgen by merging the meshed model with the meshed bounding box. I'm able to see these in Paraview, but how do I setup which of the patches of the bounding box is the inlet & outlet? Or again, would you define these separately in polyMesh?
netgenNeutralToFoam doens't load this geometry to OF because of multiple domains (netgenNeutralToFoam export results would allow editing the separate patches as inlet/outlet..), and while the fluent3DMeshToFoam loads the geometry properly, I won't be able to define the inlet/outlet because the walls are one lump of 3d data in constant/polyMesh.
Thanks for any advice!
- pm
pa-ma is offline   Reply With Quote
Gambit geometry creation: loading data to gambit C Ariyaratne FLUENT 10 March 17, 2011 16:39
Simulation of Flow through Complex 3D Geometry EmersonKB CFX 5 July 2, 2009 08:17
Fluent Geometry Limitations jpinho FLUENT 0 June 23, 2009 07:37
vitual _ real deneb FLUENT 3 January 22, 2007 04:31
CFX4.3 -build analysis form Chie Min CFX 5 July 12, 2001 23:19
