autoPtr, derived classes and memory leak
Old   July 28, 2009, 17:50
Default autoPtr, derived classes and memory leak
John Deas
johndeas is on a distinguished road
i am trying to understand generic programming concepts used in OpenFOAM, and have a basic question in C++.
suppose I have a "employee" base class which has virtual functions, and two derived classes:
employeeExportA:public employee
and
employeeExportB:public employee
I want to have a pointer to the employee base class called myEmployee, and be able to choose at runtime wether it points to a employeeExportA or employeeExportB object. I tried this code:
    auto_ptr<employee> myEmployee;
    if (inputString == "A")
         myEmployee = auto_ptr<employeeExportA>(new employeeExportA(4,5));
    if (inputString == "B")
         myEmployee = auto_ptr<employeeExportB>(new employeeExportB(4,5));;
My program compiles, but I would like to know, since the auto_ptr myEmployee has been created with the base class, will it be able to clean all the memory created by the "new" operator applied to a derived class, or will it only clean the part of the object in common with the base and let the remaining leaking ?
johndeas is offline   Reply With Quote
Old   July 29, 2009, 05:29
Assistant Moderator
Bernhard Gschaider
Originally Posted by johndeas View Post
and
That depends. Google for "virtual destructor"
