Poisseuile Flow Test
Old   December 17, 2009, 07:59
Default Poisseuile Flow Test
Stephen Wood
SWood is on a distinguished road
Hello fellow Foamers,
I'm working to verify interFoam for later two phase work with a classic Poisseuile flow test case. I've followed the suggestions on other posts to use pressureInletVelocity as the inlet boundary condition. Since the only results I've gotten show a uniform zero velocity field I suspect my B.C.'s are still not correct. Please see the contents of my boundary files and my control file below. Any suggestions sill be greatly appreciated.
Best Regards,
Stephen
FoamFile
version 2.0;
format ascii;
class volVectorField;
location "0";
object U;
dimensions [0 1 -1 0 0 0 0];
internalField uniform (0 0 0);
boundaryField
allWalls
type fixedValue;
value uniform (0 0 0);
movingWall
type fixedValue;
outlet
type pressureInletVelocity;
inlet
defaultFaces
type empty;
FoamFile
version 2.0;
format ascii;
class volScalarField;
object p;
dimensions [1 -1 -2 0 0 0 0];
internalField uniform 0;
boundaryField
allWalls
type zeroGradient;
movingWall
type zeroGradient;
inlet
type fixedValue;
value uniform 3000;
outlet
type fixedValue;
value uniform 0;
defaultFaces
type empty;
FoamFile
version 2.0;
format ascii;
class dictionary;
location "system";
object controlDict;
application interFoam;
startFrom startTime;
startTime 0;
stopAt endTime;
endTime 5.0;
deltaT 0.001;
writeControl adjustableRunTime;
writeInterval 0.05;
purgeWrite 0;
writeFormat ascii;
writePrecision 8;
writeCompression uncompressed;
timeFormat general;
timePrecision 8;
runTimeModifiable yes;
adjustTimeStep yes;
maxCo 0.5;
maxDeltaT 1;
SWood is offline   Reply With Quote
mass flow in is not equal to mass flow out saii CFX 12 March 19, 2018 05:21
Test Case: Laminar Flow Between Rotating Concentric Cylinders ebertmp OpenFOAM 4 December 3, 2012 11:54
test cases Maciej Matyka Main CFD Forum 3 November 24, 2004 08:27
flow simulation across a small fan jane luo Main CFD Forum 15 April 12, 2004 17:49
Inviscid Drag at subsonic, subcritical Mach # Axel Rohde Main CFD Forum 1 November 19, 2001 12:19
