modeling pipe flow with strong surface tension
Old   August 27, 2009, 13:51
Default modeling pipe flow with strong surface tension
Pei-Ying Hsieh
phsieh2005 is on a distinguished road
Dear OpenFOAM experts:
I would like to model a pipe flow with strong surface tension. The diameter of the pipe is 0.6 mm at 0.8 m/sec speed. liquid is water, hence the surface tension coef is 0.07. Wall contact angle is about 70 degree.
I ran the case using standard interFoam solver, but, the results are not quite what I expected. I was told that VOF cannot handle microfluidics flow with strong surface tension accurately. Does anyone come across research are in microfluidics (with liquid and air)? Any approached applied to overcome strong surface tension?
Thanks!
Pei
phsieh2005 is offline   Reply With Quote
About Turbulence Intensity (Pipe flow assimilated) gRomK13 Main CFD Forum 1 July 10, 2009 03:11
Urgent: Modeling the drag on a stationary sphere in a parabolic Pres driven pipe flow farhan CFX 4 April 9, 2009 00:36
Flow with high surface tension asder CFX 0 July 28, 2008 04:49
two phase flow with surface tension qunwuhe@hotmail.com Main CFD Forum 2 October 21, 2007 00:29
Turbulence model in flow driven by surface tension Z. ZENG Main CFD Forum 7 April 28, 1999 07:18
