Turbulent timescale
Old   September 8, 2009, 11:11
Default Turbulent timescale
Max
didomenico is on a distinguished road
Dear all,
I am currently facing the problem of determining the local turbulent timescale, and I want to implement a function which does not depend from the kind of turbulence model used (LES/RAS).
Looking inside solvers which already implement it (i.e. reacting*Foam) I have discovered something like this
volScalarField tk = Cmix*sqrt(turbulence->muEff()/rho/turbulence->epsilon());
which should indeed represent a quite general approach. However, I have the following questions:
- why does the expression contain muEff() and not mut()? According to my knowledge muEff includes the molecular viscosity. Even if this latter may be negligible in cold, high-Reynolds flows, I am pretty sure that in combustion applications the two viscosity may locallybe comparable!
- is there any other possible approach I may use to get this quantity from both LES and RAS model?
Thanks in advance,
Max
didomenico is offline   Reply With Quote
combustion, timescales, turbulence
Turbulent Boundary Layer on a Flat Plate Hoshang Garda FLUENT 1 November 27, 2013 10:24
setting value of turbulent intensity and turbulent viscosity ratio in wind tunnel nuimlabib Main CFD Forum 0 August 4, 2009 00:05
Solid Timescale Control Parthipan CFX 2 August 24, 2007 10:07
SST in 2D? Jesper Sรธrensen CFX 16 December 23, 2006 08:40
Problem of Turbulent Viscosity Ratio Limited David Yang FLUENT 3 June 3, 2002 06:13
