nNonOrthogonalCorrectors
Like Tree52Likes
  • 2 Post By sega
  • 1 Post By alberto
  • 20 Post By hjasak
  • 29 Post By hjasak
Old   October 16, 2009, 17:02
Default nNonOrthogonalCorrectors
Primoz Ternik
ternik is on a distinguished road
when simulating flow past cylinder one will (most likely) end up with the non-orthogonal mesh. How many "NonOrthogonalCorrectors" should be used? In OF-User Guide it is written that 20 "NonOrthogonalCorrectors" should be used for the most non-orthogonal meshes... Non-orthogonality of my mesh (after running checkMesh) is:
  • Max: 44.7371
  • Average: 16.8382
Thanks for your advice,
Primoz.
ternik is offline   Reply With Quote
Old   October 17, 2009, 06:35
Giovanni Ricci
gricci is on a distinguished road
Send a message via Skype™ to gricci
Maybe someone more expert will correct me, but i believe there is no fixed rule...
up now i've often set the number of nonOrthogonalCorrectors comparing the velocity profiles on a potential flow. Most of the time, I've noticed that 2 correctors are sufficient.
hope it helps
gricci is offline   Reply With Quote
Old   October 17, 2009, 07:03
sega's Avatar
Sebastian Gatzka
sega is on a distinguished road
I can confirm gricci's experience.
I have played around with the number of non-orthogonal corrector loops and found that 2 are sufficient.
If I used more than 2 corrector loops the computational time was severely increased without improving the solution.
minh khang and randolph like this.
Schrödingers wife: "What did you do to the cat? It's half dead!"
sega is offline   Reply With Quote
Old   October 17, 2009, 09:44
Primoz Ternik
Hi Sega (& Gricci),
thank you for your reply. I will give it try with with 2 (o.k. maybe 3) non-orthogonal corrector loops and... Non-orthogonal corrector loop(s) corrects the solution of pressure filed and velocity filed as well?
With greetings from Slovenia,
Primoz.
Old   October 17, 2009, 16:30
Alberto Passalacqua
I agree with 2 or 3. If you need more, it might be the case of reconsidering the mesh
minh khang likes this.
Alberto Passalacqua
Old   October 18, 2009, 04:35
Hrvoje Jasak
On this mesh you do not need non-orthogonal correctors at all. There's usually nothing to worry about until the max non-orthogonality angle is approx 70 deg.
Hrv
lakeat, happydogy, Amir and 17 others like this.
Hrvoje Jasak
Old   October 18, 2009, 07:36
Primoz Ternik
Hrv
Thanks for this - but using non-orthogonal correctors (for example 2 or 3) will result in "more accurate" results or...
Regards,
Primoz.
Old   October 18, 2009, 07:41
Hrvoje Jasak
Not really "more accurate". If you are running steady, you are doing iterations that will correct non-orthogonality (among other things), and in transient, you are running multiple PISO/SIMPLE correctors which will do the same thing.
Non-orthogonal correctorsare here to save you if your code is blowing up because the mesh is so non-orthogonal that the first solution is driving the velocity to be stupid. If your velocity is OK, you just keep doing "normal" correctors, without special need for non-orthogonal ones.
I use them on bad meshes (some people call them "industrial") when the solver is giving me trouble. Usually, 1 is enough, and I never used more than 3.
Hope this helps,
Hrvoje
lakeat, happydogy, fisch and 26 others like this.
Hrvoje Jasak
Old   October 18, 2009, 07:58
Primoz Ternik
Hope this helps,
Hrvoje
Yep, this helps. Thanks again for really helpful information on this subject.
Currently, my mesh is "academic"
With best wishes,
Primoz.
