Question regarding the F2F particle tracking algorithm implementation.
Old   October 21, 2009, 17:47
Default Question regarding the F2F particle tracking algorithm implementation.
Andrew Ryan
andrewryan is on a distinguished road
Hi all
I have read Niklas Nordin's thesis [1] about LPT. There he describes the face to face tracking algorithm (Chapter 4.2). Looking at the code in src/lagrangian/basic (in OF 1.5) I could find the F2F article again. He also mentions, that the mesh needs to be converted into a tetrahedral mesh. Otherwise calculating, whether the particle is in a cell or not, may fails. The solution to this problem is simply to decompose the hexahedral mesh into a tetrahedral mesh.
I played a bit with icoLagrangianFoam [2] and the cavityLagrangian case, where a tetrahedral mesh is generated using blockMesh. However when I look at the of code to calculate the lambdas (ParticleI.H [3]), which tells you whether a particle lies in a cell or not, I just find a reference to polyMesh. I cannot figure out where the mesh is decomposed into a hexahedral mesh.
Any ideas?
[1] http://powerlab.fsb.hr/ped/kturbo/Op...sNordinPhD.pdf
[2] http://openfoamwiki.net/index.php/Co...LagrangianFoam
[3] http://freefoam.sourceforge.net/doc/...8H_source.html
andrewryan is offline   Reply With Quote
Old   October 21, 2009, 18:18
niklas's Avatar
Niklas Nordin
niklas will become famous soon enoughniklas will become famous soon enough
It has been rewritten since then, you should look here instead.
Particle tracking in unstructured, arbitrary polyhedral meshes for CFD
and molecular dynamics,
G.B. Macpherson, N.Nordin and H.G Weller
Communications In Numerical Methods In Engineering (2008)
niklas is offline   Reply With Quote
Old   October 22, 2009, 02:55
Andrew Ryan
thx for the hint!
lagrangian, mesh
[OpenFOAM] How to do particle tracking animation with Paraview? John.I ParaView 3 June 24, 2015 10:45
Steady state particle tracking? John CFX 5 August 11, 2013 19:34
restarting lagrange (particle tracking) simulation dbdias CFX 0 September 22, 2007 20:26
particle tracking collection tank Neser CFX 1 June 1, 2006 11:06
Particle tracking in s.s and u.s.s fluid field. yueroo FLUENT 0 April 6, 2001 23:02
