problem when use foamToVTK
hi,
I'm trying to visualize my mesh witch i already verify with chekMesh and every things seems to be ok, using foamToVTK, since I use OpenFoam for simulation. the mesh was created under gmsh and converted by gmshToFoam command. I want to do this before actually computing anything but it crach with the following error message: Time 0 volScalarFields : p nuTilda k omega volVectorFields : U volTensorFields : R Internal : "/home/ouafa.bouloumou/work/RANScanal/jonction1/VTK/jonction1_1.vtk" Original cells:4430284 points:4558642 Additional cells:0 additional points:0 Cannot find face 13418476 in any of the patches 8 ( wall2 wall6 inlet2 wall4 wall5 inlet1 outlet wall1 ) It seems your patches are not consistent with the mesh : internalFaces:13163224 total number of faces:13418480#0 Foam::error::printStack(Foam::Ostream&) in "/home/ouafa.bouloumou/OpenFOAM/OpenFOAM-1.5/lib/linux64GccDPOpt/libOpenFOAM.so" #1 Foam::error::abort() in "/home/ouafa.bouloumou/OpenFOAM/OpenFOAM-1.5/lib/linux64GccDPOpt/libOpenFOAM.so" #2 Foam::polyBoundaryMesh::whichPatch(int) const in "/home/ouafa.bouloumou/OpenFOAM/OpenFOAM-1.5/lib/linux64GccDPOpt/libOpenFOAM.so" #3 Foam::pointPatchInterpolation::makePatchPatchWeigh ts() in "/home/ouafa.bouloumou/OpenFOAM/OpenFOAM-1.5/lib/linux64GccDPOpt/libfiniteVolume.so" #4 Foam::pointPatchInterpolation::pointPatchInterpola tion(Foam::fvMesh const&, Foam::pointMesh const&) in "/home/ouafa.bouloumou/OpenFOAM/OpenFOAM-1.5/lib/linux64GccDPOpt/libfiniteVolume.so" #5 Foam::volPointInterpolation::volPointInterpolation (Foam::fvMesh const&, Foam::pointMesh const&) in "/home/ouafa.bouloumou/OpenFOAM/OpenFOAM-1.5/lib/linux64GccDPOpt/libfiniteVolume.so" #6 main in "/home/ouafa.bouloumou/OpenFOAM/OpenFOAM-1.5/applications/bin/linux64GccDPOpt/foamToVTK" #7 __libc_start_main in "/lib64/libc.so.6" #8 Foam::regIOobject::readIfModified() in "/home/ouafa.bouloumou/OpenFOAM/OpenFOAM-1.5/applications/bin/linux64GccDPOpt/foamToVTK" From function label polyBoundaryMesh::whichPatch(const label faceIndex) const in file meshes/polyMesh/polyBoundaryMesh/polyBoundaryMesh.C at line 402. FOAM aborting Aborted Any ideas? Could you help me plz? Ouafa |
Have you tried checkMesh before running your model?
Ali |
thank you Ali,
yes i've tested checkMesh and it seems ok. Ouafa |
To me, there is definitely something inconsistent in your mesh. Check your mesh again and try to use a sketch for better understanding.
Ali |
ok, i re-check the mesh and i get this:
Time = constant Mesh stats points: 1080154 faces: 3160732 internal faces: 3082172 cells: 1040484 boundary patches: 8 point zones: 0 face zones: 1 cell zones: 57 Number of cells of each type: hexahedra: 1040484 prisms: 0 wedges: 0 pyramids: 0 tet wedges: 0 tetrahedra: 0 polyhedra: 0 Checking topology... Boundary definition OK. Point usage OK. Upper triangular ordering OK. Face vertices OK. Number of regions: 1 (OK). Checking patch topology for multiply connected surfaces ... Patch Faces Points Surface topology wall2 23722 24113 ok (non-closed singly connected) wall6 192 250 ok (non-closed singly connected) inlet2 960 1009 ok (non-closed singly connected) wall4 10290 10578 ok (non-closed singly connected) wall5 10290 10578 ok (non-closed singly connected) inlet1 4116 4257 ok (non-closed singly connected) outlet 4116 4257 ok (non-closed singly connected) wall1 24682 25026 ok (non-closed singly connected) Checking geometry... Overall domain bounding box (-0.1 -0.04 -0.05) (0.15 0.04 0.05) Mesh (non-empty) directions (1 1 1) Mesh (non-empty, non-wedge) dimensions 3 Boundary openness (6.0135e-17 1.02144e-14 3.04769e-15) OK. Max cell openness = 2.75831e-16 OK. Max aspect ratio = 33.6809 OK. Minumum face area = 1.91799e-08. Maximum face area = 1.71079e-05. Face area magnitudes OK. Min volume = 7.91111e-12. Max volume = 7.74162e-09. Total volume = 0.00101256. Cell volumes OK. Mesh non-orthogonality Max: 42.2568 average: 4.83306 Non-orthogonality check OK. Face pyramids OK. Max skewness = 0.586609 OK. Mesh OK. End maybe it is about the "non-closed singly connected" topology? shoud i redefine all my patches? ouafa. |
The code start the calculation, right?
If it is, please do foamToVTK -time (the first time here) and see the result. |
yes the calculations are started but even with the option ( -time 1 ) i still get the same error!!!
