calculation of gradients near wall
Old   November 5, 2009, 01:51
Default calculation of gradients near wall
Sumeet Kumar
crazysumi is on a distinguished road
Hi FOAMers,
I want to calculate gradients at the cell centroids connected to a wall patch.
The quantities I need to evaluate are :-
a) del Utau / del tau
b) del Unormal / del normal
c) del p / del tau
Here,
Utau is tangential component of velocity
Unormal is normal component of velocity
tau is a coordinate tangent to local wall face
normal is a coordinate normal to local wall face
Can someone assist me calculation of these quantities at the cell centroids. Hints and suggestions in this regard are greatly appreciated
Thanks & Regards
Sumeet
crazysumi is offline   Reply With Quote
Old   November 5, 2009, 08:54
Sumeet Kumar
Hi Again
I tried to calculate following quanitity..
1) del p / del tau
vectorField n = patch().nf() / mag( patch().nf() ) ;
volVectorField gradP(fvc::grad(db().lookupObject<volScalarField>( "p")));
const vectorField gradPInternal = gradP.boundaryField()[patchI].patchInternalField();
const scalarField gradPtau = mag(gradPInternal - n * (gradPInternal & n));
The scalarField gradPtau will give me the required derivative
However the above method cannot be reiterated for calculation of following derivatives.-
a) del U(tau) / del tau
b) del U(normal) / del normal
because the U (tau) and U (normal) vectors are only defined at the cell centroids of patchInternalField list. How do I calculate such derivatives. Please someone advice.
Regards,
Sumeet
[Commercial meshers] Fluent3DMeshToFoam simvun OpenFOAM Meshing & Mesh Conversion 50 January 19, 2020 15:33
Errors running allwmake in OpenFOAM141dev with WM_COMPILE_OPTION%3ddebug unoder OpenFOAM Installation 11 January 30, 2008 20:30
Warning 097- AB Siemens 6 November 15, 2004 04:41
Multicomponent fluid Andrea CFX 2 October 11, 2004 05:12
Wall function in adverse pressure gradients stephane baralon Main CFD Forum 11 September 2, 1999 04:05
