blockMesh can find Libraies
Old   November 10, 2009, 21:42
Default blockMesh can find Libraies
Scott
scottneh is on a distinguished road
Hello
I am finally starting to use openfoam but when I run the cavity tutorial and type "blockMesh" I get an error that says
blockMesh: error while loading shared libraries: libmeshTools.so: cannot open shared object file: No such file or directory
I suspect an enviroment variable is not properly set. Can someone tell me how to make sure openFOAM knows were to find such libraies?
Thanks
Scott
scottneh is offline   Reply With Quote
Is Playstation 3 cluster suitable for CFD work hsieh OpenFOAM 9 August 16, 2015 14:53
[Commercial meshers] BlockMesh following fluentMeshToFoam doesnbt find blockMeshDict gmcgregor OpenFOAM Meshing & Mesh Conversion 3 November 13, 2008 01:05
IcoFoam Not Installed and blockMesh command not found cesarbz OpenFOAM Installation 6 July 4, 2008 04:44
Blockmesh cavity error message tonitoney OpenFOAM Installation 2 March 17, 2008 11:59
Errors running allwmake in OpenFOAM141dev with WM_COMPILE_OPTION%3ddebug unoder OpenFOAM Installation 11 January 30, 2008 20:30
