TwoPhaseEulerFoam bed tutorial case stable in 1.5, crashes in 1.6
Old   December 2, 2009, 01:54
Default TwoPhaseEulerFoam bed tutorial case stable in 1.5, crashes in 1.6
Rasmus Hemph
hemph is on a distinguished road
I am having trouble with the solver twoPhaseEulerFoam in version 1.6.x. My cases now crashes frequently due to high volume fraction particles. This is both with and without kinetic theory. The same cases ran fine in 1.5. To illustrate the problem, try the 'bed' tutorial case, which crashes in 1.6.x and runs in 1.5.
From running diff on the source files, I can see that turbulence inclusion changed between the versions. And indeed, running with turbulence turned off, allows the 'bed'-case to finish.
Is anyone experiencing a change in stability for twoPhaseEulerFoam? Suggestions/explanations?
Best regards,
Rasmus
hemph is offline   Reply With Quote
Old   December 2, 2009, 02:57
Fabian Peng Karrholm
fabianpk is on a distinguished road
I've had the exact same problem. twoPhaseEulerFoam runs fine without the turbulence, but as soon as it is switched on it crashed after a few iterations. I tried the tutorial as well as more applied cases. Unfortunately, I haven't had the time to examine the problem further.
I assumed it was "SBS", but perhaps it wasn't so
fabianpk is offline   Reply With Quote
Old   December 4, 2009, 02:33
Rasmus Hemph
Ok. Glad to hear I am not the only one. Since the tutorial case does not run, I will put this issue on the bugs forum.
//Rasmus
Old   December 5, 2009, 04:19
Laurence R. McGlashan
l_r_mcglashan will become famous soon enough
I just ran bed in OF-1.6.x and it ran fine (with turbulence).
I guess there may have been git updates since you last compiled the solver?
Laurence R. McGlashan :: Website
l_r_mcglashan is offline   Reply With Quote
Is Playstation 3 cluster suitable for CFD work hsieh OpenFOAM 9 August 16, 2015 14:53
ChtMuliRegionFoam-Case (OF 1.6 Tutorial-case -> OF 1.5) suitup OpenFOAM 15 November 11, 2009 12:43
Forces in 1.5 with an Ahmed VWT case terrybarnaby OpenFOAM Running, Solving & CFD 3 June 9, 2009 08:21
FoamX refuses to open an interFoam tutorial case vrecha OpenFOAM Pre-Processing 5 March 12, 2008 12:36
Free surface boudary conditions with SOLA-VOF Fan Main CFD Forum 10 September 9, 2006 12:24
