InletOutlet boundary condition in motorBike tutorial |
November 27, 2009, 05:52 |
Anonymous
Rep Power: 17 |
In the motorbike tutorial, the boundary condition for velocity at the pressure outlet is set to:
type inletOutlet inlet uniform (0 0 0) outlet uniform (20 0 0) Can I ask why the inlet value has been set to (0 0 0)? I'm expecting this to be the same as what has been defined at the inlet itself, which was (20 0 0). All other quantities that use inletOutlet are set as I'd expect too. |
November 27, 2009, 07:45 |
#2 | |
Mark Olesen
Rep Power: 40 |
outlet { type inletOutlet; inletValue uniform (0 0 0); value $internalField; } Code:
outlet { type inletOutlet; inletValue $internalField; value $internalField; } The 'value' is needed to initialize the boundary condition class (also supplies a value for post-processing etc) and will be overwritten in subsequent time steps with the current values for those faces. The 'inletValue' is the value that should be used if there are any flow reversals in the system. If there is somehow a flow reversal at the outlet boundary, a zero-velocity should be a reasonable approximation of the entrainment of a quiescent fluid from teh surrounding environment. For turbulence quantities, using a zero-value for an entrainment condition when there is backflow might not be a great idea (eg, when epsilon -> zero, the equations are ill behaved). Using the same turbulence quantities as the normal inlet has can't really be exactly correct either, but probably not that bad. Even if it is a somewhat incorrect value, the flow reversal velocities are probably fairly short lived and not that strong. I don't think it should normally affect your solution. |
November 27, 2009, 08:15 |
Anonymous
Rep Power: 17 |
Thanks for the reply.
Yes, those are the entries I am talking about. My mistake was due to the fact I wasn't refering directly to the code when I posted. But, thank you for taking the time to clarify exactly was it is doing. |
Display Modes | |
problem with boundary condition??? | smn | CFX | 5 | November 24, 2009 06:37 |
RPM in Wind Turbine | Pankaj | CFX | 9 | November 23, 2009 04:05 |
Axis Boundary Condition..what is it? | CFDtoy | FLUENT | 6 | February 13, 2007 05:51 |
How to set boundary condition in Fluent for the fo | Peiyong | FLUENT | 1 | November 10, 2006 11:44 |
How to resolve boundary condition problem? | sam | FLUENT | 2 | July 20, 2003 02:19 |
