non-constant blending function
Like Tree2Likes
  • 2 Post By eugene
Old   December 8, 2009, 10:06
Default non-constant blending function
Sven Degner
sven82 is on a distinguished road
Dear Foamers,
for my Simulation I will calculate a non-constant blending factor between upwind and CDS. The definition of this factor contains turbulence parameters like epsilon.
And this is my problem, where can I implemented the code part
1. in the solver.C, but how its possible to use the turbulence describe parameters in e.g. simpleFoam.C
2. calculate the blending factor in my turbulence modell.C e.g kEpsilon in a return function, but there is the problem how its possible to link this return function to my solver.C
Thanks, for any help and I'm really hope anybody got a idea for me
Thanks a lot!
Sven
sven82 is offline   Reply With Quote
Old   December 9, 2009, 06:45
Eugene de Villiers
eugene is on a distinguished road
Hi Sven,
Your best course of action is the following.
1. Use the localBlended scheme for convections, e.g.
divSchemes
div(phi,U) Gauss localBlended linear upwind;
2. Define a surfaceScalarField called UBlendingFactor in you top level code. If this field is 1 it will use linear (CD), if this field is 0, the localBlended scheme will use the upwind. You can blend any two schemes this way. The name of the blending field is important and should be <field>BlendingFactor. The localBlended scheme will search the database for this field to use as its blending indicator.
3. To do this in you turbulence model is a bit more tricky. I strongly suggest you try to do it in the top level code. You can access most of the turbulence fields via lookups:
mesh.lookupObjectvolScalarField>("epsilon")
or via calls to the turbulence model base class:
turbulence->epsilon()()
turbulence->k()()
To perform this stuff in the turbulence model is possible. The UBlendingFactor field has to be defined before U is solved for the first time. You could do it by adding the following type of code to your turbulence model constructor:
autoPtr<surfaceScalarField> UBlendingFactor (constructor stuff);
UBlendingFactor->store(UBlendingFactor);
This will switch the ownership of the BlendingFactor object to the central database, from which you can access the object via a lookup:
mesh.lookupObject<surfaceScalarField>("UBlendingFa ctor");
Hope this helps.
nimasam and SHUBHAM9595 like this.
eugene is offline   Reply With Quote
Old   December 12, 2009, 06:34
Sven Degner
thanks eugene,
" turbulence->epsilon()()
turbulence->k()() "
this is the correct link for me,
sven
Compile problem ivanyao OpenFOAM Running, Solving & CFD 1 October 12, 2012 09:31
[blockMesh] BlockMesh FOAM warning gaottino OpenFOAM Meshing & Mesh Conversion 7 July 19, 2010 14:11
Error with Wmake skabilan OpenFOAM Installation 3 July 28, 2009 00:35
Problem with compile the setParabolicInlet ivanyao OpenFOAM Running, Solving & CFD 6 September 5, 2008 20:50
[blockMesh] Axisymmetrical mesh Rasmus Gjesing (Gjesing) OpenFOAM Meshing & Mesh Conversion 10 April 2, 2007 14:00
