Beginner's Question - cannot see grid in ParaView
Old   January 6, 2010, 12:24
Unhappy Beginner's Question - cannot see grid in ParaView
Steffen K.
fishlurch is on a distinguished road
I just installed OpenFOAM and have some starting problems. I read a little bit in the documentation and want to test the first example (in tutorials/incompressible/icoFoam/cavity)
I create the gridFile via the "blockMesh" command - everything seems to work fine. But when calling paraView, I cannot see my grid. I already changed all available color settings but nothing changes - i cannot see anything. All I see is the patch names.
Where can be my mistake. Also when I try to calculate a solution via "paraFOAM" everything works fine and also the data is displayed in the tables of "paraView". But no pictures... it is hard to start when even the simplest examples does not work properly...
Thanks a lot
Greez
Steffen
fishlurch is offline   Reply With Quote
Old   January 6, 2010, 12:39
Steffen K.
by the way - i did not compile the third party programs by myself but used the kubuntu package managemt to install all the dependencies, but I think that might not be a problem?
Old   January 7, 2010, 06:32
Aniko Rakai
ancsa is on a distinguished road
Did you check this thread?
http://www.cfd-online.com/Forums/ope...-paraview.html
if your ubuntu is not english there might be solution for you
ancsa is offline   Reply With Quote
Old   January 7, 2010, 10:49
Default That helped
Steffen K.
I also found this thread yesterday and what finally fixed the problem was inserting "export LC_ALL=C" as first line in"$/HOME/OpenFoam/OpenFoam-1.6/bin/paraFoam".
Thanks for help :-)
On grid independent solution for pulsatile flow David FLUENT 5 March 25, 2022 04:33
Question on changing a grid RockaFella FLUENT 0 October 29, 2009 10:35
Question about grid scaling... Iaroslav FLUENT 3 May 15, 2009 05:03
Moving Body Grid Question Matt Main CFD Forum 5 September 13, 2004 01:45
Numerical methods for discontinuous grid interfaces? Hansong Hang Main CFD Forum 12 September 16, 1998 23:26
