December 29, 2009, 09:49 |
Multiphase flows (oil with small particles)
Sami Lakka
Rep Power: 17 |
I stumbled in to an interesting case where I would need to get most of the small particles in oil to collide with pipe wall (or other obstruction). In order to look into this I need to simulate how small oil particles (10 - 100 microns) flow in oil. What would be the preferred solver for this case?
January 10, 2010, 17:35 |
Alberto Passalacqua
Rep Power: 36 |
You should give some indication of how many particles (concentration, volume fraction) you want to consider if you want a reliable answer.
If the flow is relatively dilute (particle volume fraction < 10%), you can use a lagrangian solver, while for higher volume fractions you need other approaches (Euler-Euler, for example). Best,
Alberto Passalacqua GeekoCFD - A free distribution based on openSUSE 64 bit with CFD tools, including OpenFOAM. Available as in both physical and virtual formats (current status: http://albertopassalacqua.com/?p=1541) OpenQBMM - An open-source implementation of quadrature-based moment methods. To obtain more accurate answers, please specify the version of OpenFOAM you are using. |
multiphase modelling |
Difference of multicomponent and multiphase homogenous flows | Luk_Fiz | CFX | 11 | April 4, 2013 05:29 |
multiphase oil air separator tips | matt giuli | CFX | 1 | October 6, 2008 22:50 |
Free surface flows and multiphase flows | Vidar | Main CFD Forum | 0 | September 18, 2008 05:05 |
Continuity equation for Multiphase flows? | discoganya | Main CFD Forum | 0 | June 29, 2006 13:39 |
Multiphase Flows | Elliot Schwartz | Main CFD Forum | 6 | May 28, 1999 02:11 |
