number of iterations exceeded From function specieThermo
Old   September 16, 2010, 23:36
Default number of iterations exceeded From function specieThermo
Alex
bruxellois is on a distinguished road
I am trying to solve a case with sonicFoam with time dependent BC (INLET ={p =45Mpa-->101325 Pa, U=1000-->0 and T 2000k-->300K} and outlet = zerogradient for all fields).
After some iterations i got this error message:
Maximum number of iterations exceeded#0 Foam::error:rintStack(Foam::Ostream&) in "/home/moumen/OpenFOAM/OpenFOAM-1.6/lib/linux64GccDPOpt/libOpenFOAM.so"
#1 Foam::error::abort() in "/home/moumen/OpenFOAM/OpenFOAM-1.6/lib/linux64GccDPOpt/libOpenFOAM.so"
#2 Foam::ePsiThermo<Foam:ureMixture<Foam::constTran sport<Foam::specieThermo<Foam::hConstThermo<Foam:: perfectGas> > > > >::calculate() in "/home/moumen/OpenFOAM/OpenFOAM-1.6/lib/linux64GccDPOpt/libbasicThermophysicalModels.so"
#3 Foam::ePsiThermo<Foam:ureMixture<Foam::constTran sport<Foam::specieThermo<Foam::hConstThermo<Foam:: perfectGas> > > > >::correct() in "/home/moumen/OpenFOAM/OpenFOAM-1.6/lib/linux64GccDPOpt/libbasicThermophysicalModels.so"
#4 main in "/home/moumen/OpenFOAM/OpenFOAM-1.6/applications/bin/linux64GccDPOpt/sonicFoam"
#5 __libc_start_main in "/lib/libc.so.6"
#6 _start at /usr/src/packages/BUILD/glibc-2.9/csu/../sysdeps/x86_64/elf/start.S:116
From function specieThermo<thermo>::T(scalar f, scalar T0, scalar (specieThermo<thermo>::*F)(const scalar) const, scalar (specieThermo<thermo>::*dFdT)(const scalar) const) const
in file /home/dm2/henry/OpenFOAM/OpenFOAM-1.6/src/thermophysicalModels/specie/lnInclude/specieThermoI.H at line 68.
FOAM aborting
Aborted
Has anyone experienced an error like the above? Any suggestions on what it might be?
Any help will be appreciated
Best regards.
bruxellois is offline   Reply With Quote
Old   September 17, 2010, 03:03
Christian Lucas
Chris Lucas is on a distinguished road
this problem is quite common. Have a look through the forum.
The problem is most probably related to pressure field. Have a look at it at a time step before the error occurs. I guess you have negative pressures, so the thermophysical library crashes.
Regards,
Christian
Chris Lucas is offline   Reply With Quote
Old   September 17, 2010, 03:09
Alex
thanks for your response,
If so how can i fix that!
Old   October 27, 2010, 06:16
83_Ale_83's Avatar
Alessandro
83_Ale_83 is on a distinguished road
Hi have solved the problem by changing the controlDict file:
writeControl adjustableRunTime;
and
adjustTimeStep yes;
Hope this help
83_Ale_83 is offline   Reply With Quote
Old   August 28, 2013, 04:48
starter
sihaqqi is on a distinguished road
All
I have the same issue and I have been referring the forum but cannot find a solution that can get rid of this error for me. I have tried Alessandro's method but to no avail. Alex, kindly advise what you did to resolve max number of iterations exceeded.
I shall be very obliged.
Regards
sihaqqi is offline   Reply With Quote
[mesh manipulation] Mesh Refinement Luiz Eduardo Bittencourt Sampaio (Sampaio) OpenFOAM Meshing & Mesh Conversion 42 January 8, 2017 12:55
On the damBreak4phaseFine cases paean OpenFOAM Running, Solving & CFD 0 November 14, 2008 21:14
Parallel rasInterFoam openfoam_user OpenFOAM Running, Solving & CFD 4 November 1, 2008 04:14
MRFSimpleFoam amp cyclic patches david OpenFOAM Running, Solving & CFD 36 October 21, 2008 21:55
Droplet Evaporation Christian Main CFD Forum 2 February 27, 2007 06:27
