Parallel kill from inside the code
Old   January 25, 2010, 06:00
Default Parallel kill from inside the code
John Deas
johndeas is on a distinguished road
I got a modified version of channeloodles that contains this piece of code:
MPI_BARRIER
if (Pstream::master())
    myPipe.push(runTime.timeName());
    if(myPipe.pull()=="noFile" && feederStop)
        Info << "!!! NO VALID INLET FOUND, ENDING RUN !!!";
        myPipe.push("exit");
        std::exit(0);
MPI_BARRIER
The statement
is tested on the master proc only, and if it is false, the whole computation should stop immediately. This is part of a system I have written to manage DNS boundary conditions, and the "false" case corresponds to a case where no boundary conditions can be found for the current time.
MPI_BARRIER being a simple reimplementation as read in http://www.cfd-online.com/Forums/ope...tml#post234765
This piece of code works in serial execution, but in parallel run, std::exit(0) is only executed in the master proc. I would like a method so that, if the master proc detects a termination condition, all run exit. It can be noted that, while the master proc is testing the termination condition, the other procs are waiting for a reduction, as defined in MPI_BARRIER in the other thread.
I would be happy even if the run could end abruptly, all processes just have to end. Can mpirun be asked to broadcast a kill signal to all the processes, for example ?
Thank you
JD
johndeas is offline   Reply With Quote
IcoFoam parallel woes msrinath80 OpenFOAM Running, Solving & CFD 9 July 22, 2007 02:58
Problems with MFIX code and Parallel Processing. Fernando Pio Main CFD Forum 4 August 29, 2006 14:33
Design Integration with CFD? John C. Chien Main CFD Forum 19 May 17, 2001 15:56
What is the Better Way to Do CFD? John C. Chien Main CFD Forum 54 April 23, 2001 08:10
own Code vs. commercial code Bernhard Mueck Main CFD Forum 10 February 16, 2000 10:07
