March 3, 2010, 09:54 |
RAE2822 Airfoil using rhoSimpleFoam
Dear Foamers!
I am currently trying to simulate a flow around a RAE2822 airfoil. Here are the inlet conditions: Re=500 then Re= 6,500,000 Mach=0.5, AoA=2.92°. I want to use rhoSimpleFoam solver to do so. First, I wanted to simulate the turbulent flow and then I decided to go back to laminar flow. My domain is composed of : upstream and downstream, limitbox, intrados, extrados and symmetry. I am using the following boundary conditions (please find them in attachments). The simulation starts but fails within three steps. The error is the following: Foam::GAMGSolver::scalingFactor(Foam::Field<double >&, Foam::Field<double> const&, Foam::Field<double> const&, Foam::Field<double> const&) const in "/home/EUCLIDE/truong_nm/OpenFOAM/OpenFOAM-1.6/lib/linux64GccDPOpt/libOpenFOAM.so" #4 Foam::GAMGSolver::scalingFactor(Foam::Field<double >&, Foam::lduMatrix const&, Foam::Field<double>&, Foam::FieldField<Foam::Field, double> const&, Foam::UPtrList<Foam::lduInterfaceField const> const&, Foam::Field<double> const&, unsigned char) const in "/home/EUCLIDE/truong_nm/OpenFOAM/OpenFOAM-1.6/lib/linux64GccDPOpt/libOpenFOAM.so" #5 Foam::GAMGSolver::Vcycle(Foam::PtrList<Foam::lduMa trix::smoother> const&, Foam::Field<double>&, Foam::Field<double> const&, Foam::Field<double>&, Foam::Field<double>&, Foam::Field<double>&, Foam::PtrList<Foam::Field<double> >&, Foam::PtrList<Foam::Field<double> >&, unsigned char) const in "/home/EUCLIDE/truong_nm/OpenFOAM/OpenFOAM-1.6/lib/linux64GccDPOpt/libOpenFOAM.so" #6 Foam::GAMGSolver::solve(Foam::Field<double>&, Foam::Field<double> const&, unsigned char) const in "/home/EUCLIDE/truong_nm/OpenFOAM/OpenFOAM-1.6/lib/linux64GccDPOpt/libOpenFOAM.so" Thus, it seems to be due to my schemes parameters. I also attach them. I searched the forum for similar cases, I tried parameters according what I found but still unsucessfully. Can someone help me to set this case up ? The mesh comes from Fluent. I converted it using fluent3DMeshToFoam and then scale it to get Re = 500. Thanks for your help and your answers, Minh (email: mysttruong@hotmail.com) 0.zip constant.zip system.zip |
November 18, 2019, 13:26 |
#2 | |
mohammed mahdi
i suggest to use sst, or spalart almaras |
Low Speed Airfoil | Mancusi | FLUENT | 7 | April 3, 2014 06:11 |
Modeling Backflow for a 3D Airfoil (Wing of Finite Span) | Josh | CFX | 9 | August 18, 2009 11:31 |
Airfoil boundary condition | Frank | Main CFD Forum | 1 | April 21, 2008 18:36 |
Compressible transonic airfoil RAE2822 simulation | Stefano | Siemens | 9 | June 21, 2006 10:47 |
need RAE2822 airfoil data,help! | zqnwpu | Main CFD Forum | 2 | May 1, 2003 05:19 |
